- To: "" <>
- Subject: Re: [cgal-discuss] What's the most efficient configuration for nef_3
- Date: Wed, 11 Jun 2008 08:19:04 +0800
- Organization: Max
>On Tue, 2008-06-10 at 17:08 +0800, Max wrote:
>> >Hi Max,
>> >> In one of my program, I use boolean operation of Nef_3 heavily,
>> >> and I found the efficiency of it became the bottleneck of the
>> >> program, because I need to compute the result of boolean for thousands
>> >> of times.
>> >> Now I want to know, if I don't need the result to be *exact*, which
>> >> configuration(Kernel, Item, etc.) would be the most efficient?
>> >The best kernel usually is the
>> >Exact_constructions_exact_predicates_kernel. I say usually, because this
>> >kernel resolves into different kernels dependent upon your installation.
>> >So, you should have gmp installed, otherwise this kernel will not be
>> >efficient.
Another question, how can I determine the resolved type of
Exact_constructions_exact_predicates_kernel at rune time or compile time?
>> I'm a little bit confused on 'whether I have installed GMP'.
>> I have selected to install the pre-compiled lib's during the installation
>> of CGAL.
>> As a result, there's an auxiliary\gmp folder under the CGAL root folder.
>> There're
>> header files and lib files of GMP and MPFR for VC71 and VC80 in this
>> folder.
>> I guess this is not enough to considered as "GMP installed", then I
>> downloaded GMP 4.2.1 and MPFR 2.2.0 and compiled with VC9.
>> After a lot of efforts, I finally got to link by program with these
>> new libs. But I could hardly detect any increase of efficiency.
>> This lead me to the understanding - my previous condition could be
>> considered as
>> "GMP installed". Right?
>Just try to use Gmpz or Gmpq as a number type. If you can compile, you
>have Gmp. You can also look up in CGALHOME/make/makefile<yoursystem>
Thank you for your clarification. I can and could use GmpX as Kernel after
and before I re-compiled the Gmp lib's.
In my CGALHOME/make folder, there's only a README file.
>> >Remember to use the SNC_indexed_items together with every kernel you
>> >use. That makes it faster. So
>> >typedef Nef_polyhedron_3<Kernel, SNC_indexed_items> Nef_3;
>> >I guess you are already doing that, aren't you?
>> If your have told me the difference in efficiency of the default items type
>> and the indexed items, I should have been using the indexed one. :-)
>> But the fact is 'no'. :-(
>> The reason should be either I haven't been told of this or I have tried
>> with it but have met some difficulties.
>> Anyway, I shifted, back or not, :-), to the indexed items type. But I
>> found
>> the program behaves differently - it can even not run correctly, error
>> arises
>> before it ends.
>> I will debug the program and report more details.
>The system is supposed to behave the same way with the indexed items.
>The only difference should be in input and output of coordinates. If you
>have bugs, then send them to me. I will do the debugging. It's important
>for me to make the indexed items as reliable as possible.
The context of the error is as the attached sreenshot.
If it's not enough, I'll prepare a minimum program that can reproduce the
problem.
One thing to note: I'm reading a nef_3 from a .nef file.
And I've refreshed the .nef file from an identical .off model (very simple)
using the nef_3 type with the indexed items type. (I've not found any
significant
difference in format from the two .nef files written from two identical nef_3
with different items types)
>> >Explain your scenario. Then I might can help you to improve. Do you
>> >always intersect a polyhedron with a plane? Do the polyhedra have
>> >special properties? Are they small or large? Are they convex? Are they
>> >two-manifold? What do you do with the resulting polygon?
>> Here are some aspects of my scenario:
>> - I'm dealing with float type coordinates of vertices of the polyhedrons
>> - I often intersect a nef_3 with a plane with such idiom:
>> Plane_3 p;
>> Nef_3 N = Nef_3(p).intersection(p).intersection(p.opposite());
Sorry, it's a typo, it should be:
Plane_3 p;
Nef_3 N;
Nef_3 result = N.intersection(p).intersection(p.opposite());
>> - the original polyhedron I'm dealing with is 2-manifold.
>> - I convert back the resulting nef_3 of intersection into
>> polyhedron and calculate the geometric properties of it.
>> (I now this is one unnecessary step which was consuming my precious CPU
>> cycles,
>> but this should not be the bottole neck of the whole program. I've put
>> this in my
>> TODO list to handle nef_3 directly)
>> - I don't need the operation to be _strictly_ exact, I could
>> accept some level of tolerance of real type computation
>> - I want the configuration to be as efficient as possible.
>I hope the indexed items speed up your program significantly. What I can
>also do is, that I allow you to intersect with the plane and not twice
>with halfspaces. That should give you a factor of two.
I'm interested in your updated opinion on my correction above.
Thank you again, Peter.
B/Rgds
Max
>Peter
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
Description: Binary data
- Re: [cgal-discuss] 3D surface Mesh Generation, (continued)
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/11/2008
- [cgal-discuss] format and viewer for the 3D surface Mesh Generation, Hui Ding, 06/12/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Laurent Rineau, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Marco Attene, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Max, 06/11/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
- Re: Re: [cgal-discuss] What's the most efficient configuration for, Max, 06/11/2008
