- To:
- Subject: Re: [cgal-discuss] question on splitting edges
- Date: Tue, 17 Jun 2008 02:57:09 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=rc5SPboLegSOBTpHs4Sr2oS6ZKHz8RX9kJSfIb+WkVPMztCzPM93mGZFuqmCiQhqd8 eTikB5fNazFbJ0fOG4rIyu9XtIo+zaaZBrnf0qNLJ5Q5EJ8AiXqQLVRdRdv472pNtRmP WnMoL9CRxavZVF63J/w+VFJ1Sw/8ml9T8gWC8=
hello Andreas,
thank you very much. I think that is an option, but is that efficient?
I'm wondering how people do this kind of operation normally?
for example, when applying a subdivision on a geometry object,
should i make a cloned object and do all the modification on it and
return the cloned one, or i just need to modify the original one.
i know the first way is easier to implement and also safer, but it
eats up more memory.
i think those commercial software, say 3D max, always keeps the
original geometry and do modification on a cloned object.
thank you,
On Mon, Jun 16, 2008 at 3:13 PM, Andreas Fabri
wrote:
> Hello Bill,
> what you might do is to copy the edges you want to split
> into a container and then just split them.
> The behaviour of an iteration over the edges as they are stored in the
> datastructure itself interlaced with operations modifying the datastructure
> depends too much on how they are stored.
> andreas
> Bill Conan wrote:
>> hello Pierre,
>> thank you very much for your reply. but i don't want to make things
>> complicated. i just need to split each edge into two.
>> so here is my understanding: if i split an edge e into e1 and e2,
>> then e1 will be at the same location in the edge list as the edge e is,
>> and e2 will be added to the end of the list.
>> so if i write the code as this
>> enditer=edge.end();
>> for(edgeiter=edge.begin();edgeiter<enditer;++edgeiter)
>> split edgeiter;
>> // will edgeiter become null here?
>> i'll be fine (the code will not loop forever). am i right?
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Dept. of Computer Science
University of California, Davis
Homepage:http://wwwcsif.cs.ucdavis.edu/~yans/
- [cgal-discuss] question on splitting edges, Bill Conan, 06/15/2008
- Re: [cgal-discuss] question on splitting edges, Pierre Alliez, 06/15/2008
- Re: [cgal-discuss] question on splitting edges, Bill Conan, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Andreas Fabri, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Bart Janssens, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Bill Conan, 06/17/2008
