- To:
- Subject: Re: [cgal-discuss] question on splitting edges
- Date: Tue, 17 Jun 2008 07:04:02 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=ZrYb+94KjaCd5Ljy5oyz99LRPtX8xguvQlzkpIin7w6jLwTG2J+MNPcjHm1bh+/7i3 yx0nxGt0le5/zr6WND7dJX9RTj5XBgdlbxiNy0qypqVQEzr/OfFHWUfkRLRSy7h4PkKs lgG5jKYB5rXRFtDtJCsjwRZSfHilvzqO8Acqw=
thanks Bart,
i did an experiment, the truth is that if i split an edge e, the newly
generated sub edges will be at the old position of e.
suppose the original edge list is e1->e2->e3->e4
now if i want to split the e2 to eA and eB, then the list will be like
this e1->eA->eB->e3->e4
therefore, if i write the code as this:
Edge_iterator iter=p.edges_begin();
Edge_iterator iterE=p.edges_end();
for(iter;iter!=iterE;++iter)
p.split_edge(iter);
it will loop forever,
the correct code should be like this:
p.split_edge(iter);
++iter;
cheers,
On Tue, Jun 17, 2008 at 3:46 AM, Bart Janssens
wrote:
> On 6/16/08, Bill Conan
> wrote:
>> I'm wondering how people do this kind of operation normally?
>> for example, when applying a subdivision on a geometry object,
> Hi Bill,
> K-3D meshes used to have a structure similar to the CGAL Halfedge
> structure. To split edges, we traveled along the edges using the
> next() method, making sure to store a handle to the old "next" edge
> before moving on. Pseudo code would be like this:
> For each facet
> Get first edge first_edge
> while edge != first_edge
> old_clockwise = edge->next()
> split edge
> edge = old_clockwise
> Dunno if this is OK in CGAL, though. Also, you might need to make sure
> the opposite edges remain in sync.
> Cheers,
> Bart
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] question on splitting edges, Bill Conan, 06/15/2008
- Re: [cgal-discuss] question on splitting edges, Pierre Alliez, 06/15/2008
- Re: [cgal-discuss] question on splitting edges, Bill Conan, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Andreas Fabri, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Bart Janssens, 06/16/2008
- Re: [cgal-discuss] question on splitting edges, Bill Conan, 06/17/2008
