[cgal-discuss] [Newbie] Polyhedron_incremental_builder_3 and test_facet_indices
- To:
- Subject: [cgal-discuss] [Newbie] Polyhedron_incremental_builder_3 and test_facet_indices
- Date: Mon, 16 Jun 2008 22:00:48 +0200
Dear CGAL users,
I'm trying to get Polyhedron_incremental_builder_3 working for me.
I have the classical problem of having a surface given as triangles
but with uncoherent orientation. Thus before tossing out the triangles
to the incremental_builder_3, I use test_facet_indices() as an orientation
predicate and revert the triangle order when the test rejects one triangle.
[and yes they are many ways to orient the triangulation from outside
CGAL but this is not what we needl.
I must be doing things really wrong because I couldn't get it working
even for the following example for which the surface has only two
triangles [ I compile it with
g++ polySurface.cpp -lCGAL -lCGALcore++ -o polySurface -Wall] .
I would really appreciate any kind of help on this problem.
Best.
Eric Boix.
#include <iostream> // for cout
#include <stdlib.h> // for exit
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Triangle_3.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
template <class HDS>
class Build_Surface : public CGAL::Modifier_base<HDS>
public:
Build_Surface() { }
void operator()( HDS& hds );
void Build_Surface< HDS >::operator()( HDS &hds )
/// Build a simple surface made of two triangles.
CGAL::Polyhedron_incremental_builder_3<HDS> pB(hds, true);
pB.begin_surface( 6, 2, 0);
typedef typename HDS::Vertex::Point Point;
pB.add_vertex( Point( 0.0, 0.0, 0.0));
pB.add_vertex( Point( 1.0, 0.0, 0.0));
pB.add_vertex( Point( 0.0, 1.0, 0.0));
pB.add_vertex( Point( 0.0, 0.0, 1.0));
pB.add_vertex( Point( 1.0, 1.0, 1.0));
pB.add_vertex( Point( 1.0, 0.0, 1.0));
// First triangle:
pB.begin_facet();
pB.add_vertex_to_facet(2);
pB.add_vertex_to_facet(4);
pB.add_vertex_to_facet(0);
pB.end_facet();
// Second triangle:
std::vector< std::size_t> t;
t.push_back(0); t.push_back(5); t.push_back(4);
if( pB.test_facet_indices(t) == true )
std::cout << "Test passed." << std::endl;
else
std::cout << "Test failed." << std::endl;
exit( 0 ) ;
pB.begin_facet();
pB.add_vertex_to_facet(t[0]);
pB.add_vertex_to_facet(t[1]);
pB.add_vertex_to_facet(t[2]);
pB.end_facet();
pB.end_surface();
int main()
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
Polyhedron P;
Build_Surface<HalfedgeDS> surface;
P.delegate(surface);
std::cout << "Done with surface building." << std::endl;
return 0;
#include <iostream> // for cout #include <stdlib.h> // for exit #include <CGAL/Simple_cartesian.h> #include <CGAL/Triangle_3.h> #include <CGAL/Polyhedron_incremental_builder_3.h> #include <CGAL/Polyhedron_3.h> template <class HDS> class Build_Surface : public CGAL::Modifier_base<HDS> { public: Build_Surface() { } void operator()( HDS& hds ); }; template <class HDS> void Build_Surface< HDS >::operator()( HDS &hds ) { /// Build a simple surface made of two triangles. CGAL::Polyhedron_incremental_builder_3<HDS> pB(hds, true); pB.begin_surface( 6, 2, 0); typedef typename HDS::Vertex::Point Point; pB.add_vertex( Point( 0.0, 0.0, 0.0)); pB.add_vertex( Point( 1.0, 0.0, 0.0)); pB.add_vertex( Point( 0.0, 1.0, 0.0)); pB.add_vertex( Point( 0.0, 0.0, 1.0)); pB.add_vertex( Point( 1.0, 1.0, 1.0)); pB.add_vertex( Point( 1.0, 0.0, 1.0)); // First triangle: pB.begin_facet(); pB.add_vertex_to_facet(2); pB.add_vertex_to_facet(4); pB.add_vertex_to_facet(0); pB.end_facet(); // Second triangle: std::vector< std::size_t> t; t.push_back(0); t.push_back(5); t.push_back(4); if( pB.test_facet_indices(t) == true ) std::cout << "Test passed." << std::endl; else { std::cout << "Test failed." << std::endl; exit( 0 ) ; } pB.begin_facet(); pB.add_vertex_to_facet(t[0]); pB.add_vertex_to_facet(t[1]); pB.add_vertex_to_facet(t[2]); pB.end_facet(); pB.end_surface(); } int main() { typedef CGAL::Simple_cartesian<double> Kernel; typedef CGAL::Polyhedron_3<Kernel> Polyhedron; typedef Polyhedron::HalfedgeDS HalfedgeDS; Polyhedron P; Build_Surface<HalfedgeDS> surface; P.delegate(surface); std::cout << "Done with surface building." << std::endl; return 0; }
- [cgal-discuss] [Newbie] Polyhedron_incremental_builder_3 and test_facet_indices, Eric Boix, 06/16/2008
