cgal-discuss - Re: [cgal-discuss] Problem with Convex Hull, again
  • To:
  • Subject: Re: [cgal-discuss] Problem with Convex Hull, again
  • Date: Thu, 19 Jun 2008 10:13:44 +0800
Ashwin Nanjappa wrote:
I have already found that is nothing wrong with my code, that it works fine in Linux with g++ compiler, for example. The problem is that didn't work with any Visual Studio 2005 here in my university. What compile and platform are you using over there?
I'm on Visual C++ 2008 Express Edition and with the point set you shared I can see the same error that you mentioned. It is indeed strange that you don't get this error when you try it with g++/Linux. The error doesn't happen if I change the kernel from Exact_predicates_inexact_constructions to E_p_exact_constructions.
I've attached the call stack of this exception to this email. What is strange is that it seems to be failing in a predicate, rather than in a construction. Maybe the others in this list can shed some light on that.
Regards,
~ash
1 Triangulation_3.exe!std::_Debug_message(const wchar_t *
message=0x0055e818, const wchar_t * file=0x0055e698, unsigned int line=1122)
*2 Triangulation_3.exe!std::vector<short,std::allocator<short>
>::_Insert_n(std::_Vector_iterator<short,std::allocator<short> > _Where=...,
unsigned int _Count=1, const short & _Val=3)
3 Triangulation_3.exe!std::vector<short,std::allocator<short>
>::insert(std::_Vector_iterator<short,std::allocator<short> > _Where=...,
4 Triangulation_3.exe!std::vector<short,std::allocator<short>
>::push_back(const short & _Val=3)
5
Triangulation_3.exe!CGAL::MP_Float::construct_from_builtin_fp_type<double>(double
d=2.6954690000000001)
6 Triangulation_3.exe!CGAL::MP_Float::MP_Float(double
7
Triangulation_3.exe!CGAL::Split_double<CGAL::MP_Float>::operator()(double
d=2.6954690000000001, CGAL::MP_Float & num={...}, CGAL::MP_Float & den={...})
8
Triangulation_3.exe!CGAL::Quotient<CGAL::MP_Float>::Quotient<CGAL::MP_Float>(const
double & n=2.6954690000000001)
9
Triangulation_3.exe!CGAL::NT_converter<double,CGAL::Quotient<CGAL::MP_Float>
>::operator()(const double & a=2.6954690000000001)
10
Triangulation_3.exe!CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
>,CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float>
>,CGAL::NT_converter<double,CGAL::Quotient<CGAL::MP_Float> >
>::operator()(const
CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > &
a={...})
11
Triangulation_3.exe!CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float>
>,CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<0>
>,CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>,CGAL::Simple_cartesian<CGAL::Interval_nt<0>
>,CGAL::NT_converter<double,CGAL::Interval_nt<0> >
>,1>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian
<double> >
>,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
>,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >
>(const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
> & a1={...}, const
a2={...}, const
a3={...}, const
a4={...})
12
Triangulation_3.exe!CGAL::SF_Orientation_3<CGAL::Filtered_kernel_base<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > >
>::operator()(const
p={...}, const
q={...}, const
r={...}, const
s={...})
13
Triangulation_3.exe!CGAL::Point_triple_has_on_positive_side_3<CGAL::Convex_hull_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >::operator()(const
CGAL::Point_triple<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > &
pl={...}, const
p={...})
14
Triangulation_3.exe!CGAL::non_coplanar_quickhull_3<CGAL::Polyhedron_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>,CGAL::Polyhedron_items_3,CGAL::HalfedgeDS_default,std::allocator<int>
>,CGAL::Convex_hull_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>(std::list<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>,std::allocator<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
points=[87]({...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},{...},...),
>,CGAL::Polyhedron_items_3,CGAL::HalfedgeDS_default,std::allocator<int> > &
P={...}, const
> > & traits={...})
15
Triangulation_3.exe!CGAL::ch_quickhull_polyhedron_3<std::list<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::_Iterator<0>,CGAL::Polyhedron_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > > >::_Iterator<0> point1_it={...},
> > > >::_Iterator<0> point2_it={...},
> > > >::_Iterator<0> point3_it={...},
P={...}, const
> > & traits={...})
16
Triangulation_3.exe!CGAL::convex_hull_3<std::_Vector_iterator<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>(std::_Vector_iterator<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > > > first={...},
> > > > beyond={...},
polyhedron={...}, con
st
> > & traits={...})
17
> > > > first={...},
> > > > beyond={...},
polyhedron={...})
18 Triangulation_3.exe!main()
19 Triangulation_3.exe!__tmainCRTStartup()
20 Triangulation_3.exe!mainCRTStartup()
21 kernel32.dll!RegisterWaitForInputIdle()
22 [Frames below may be incorrect and/or missing, no symbols loaded for
kernel32.dll]
