- To:
- Subject: Re: [cgal-discuss] Problem with Convex Hull, again
- Date: Fri, 20 Jun 2008 09:44:55 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:references:x-google-sender-auth; b=HvGFdPmfEW/ZhUtYCmKAcigw50622RKm6tPBeFc2DPKMloJO9S2bbVHcCPo4IIX/0K 4DHyjMS++p1QQJxmUum2lKw8VaDgM1jQ0AYxZ+7wNSFrafF2oYZwBopK2Ibit3tdSS1i u9rYP9btoG+gFaq/honCX5iBlHQR9MabCI84Q=
Hello everyone,
Ashwin, its works fine to me too when I change to Exact_predicates_exact_constructions, like you said. I have no idea what this problem could be, I'm starting using CGAL just now, so I still have much to learn to see those things.
And wasn't me that ran this code with g++ in Linux. Unfortunately we don't have Linux here, so I couldn't make this test, but Bernd (a list member) said to me that this worked fine with him in those conditions.
But now, I have a doubt: what is the real difference beteween Exact_predicates_exact_constructions to Exact_predicates_inexact_constructions?
Thank you all,
Rafael Roberto
- [cgal-discuss] Problem with Convex Hull, again, Rafael Roberto, 06/17/2008
- Re: [cgal-discuss] Problem with Convex Hull, again, Ashwin Nanjappa, 06/18/2008
- Re: [cgal-discuss] Problem with Convex Hull, again, Ashwin Nanjappa, 06/19/2008
- Message not available
- Re: [cgal-discuss] Problem with Convex Hull, again, Rafael Roberto, 06/20/2008
- Re: [cgal-discuss] Problem with Convex Hull, again, Ashwin Nanjappa, 06/20/2008
