- To: <>
- Subject: RE: [cgal-discuss] 3D surface mesh generation
- Date: Tue, 24 Jun 2008 13:02:56 +0000
- Importance: Normal
Thank you! and also in this case(all the facets are triangles), i need to know the every three vertices on the same facet which is on the surface, but I didnt find the direct way to do it, do you have an idea? > > On Tuesday 24 June 2008 12:24:34 Hui Ding wrote: > > Hi, > > > > Since I made my implicit function, I got an > > "Surface_mesh_default_triangulation_3" which I named it "tr". My question > > is: Is there anyway to return only the facets or vertices of the surface? > > Thanks a lot. > > Use the 2D complex in 3D triangulation. The variable is probably named c2t3. > The documentation is here: > http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher_ref/Concept_SurfaceMeshComplex_2InTriangulation_3.html > > A facet f is on the surface iff c2t3.face_status(f)!=NOT_IN_COMPLEX. If you > want to iterate of facets of the surface, you can use the sequence > c2t3.facets_begin(), c2t3.facets_end() > The iterators have type Facet_iterator (defined in the C2T3). > > -- > Laurent Rineau, PhD > Engineer at GeometryFactory > http://www.geometryfactory.com/ > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss Get news, entertainment and everything you care about at Live.com. Check it out! |
- [cgal-discuss] Thinning a polygon / inner polygon offsetting, ajaenicke, 06/23/2008
- Re: [cgal-discuss] Thinning a polygon / inner polygon offsetting, Andreas Fabri, 06/24/2008
- Re: [cgal-discuss] Thinning a polygon / inner polygon offsetting, Wolfgang Aigner, 06/24/2008
- [cgal-discuss] 3D surface mesh generation, Hui Ding, 06/24/2008
- Re: [cgal-discuss] 3D surface mesh generation, Laurent Rineau, 06/24/2008
- RE: [cgal-discuss] 3D surface mesh generation, Hui Ding, 06/24/2008
- Re: [cgal-discuss] 3D surface mesh generation, Hui DING, 06/24/2008
