- To:
- Subject: [cgal-discuss] Arrangement_2 IO problem
- Date: Tue, 24 Jun 2008 15:42:33 +0200
Hi list,
I have got a strange problem with the Arrangement_2 IO. Here is a part of my program:
Naive_pl naive_pl(arr);
point_location_query(naive_pl, source);
// Write the arrangement to a file
std::ofstream out_file("output/arr_io.dat");
Formatter formatter;
write(arr, out_file, formatter);
out_file.close();
// Read the arrangement from a file
std::ifstream in_file2("output/arr_io.dat");
Arrangement_2 arr2;
read(arr2, in_file2, formatter);
in_file2.close();
assert(arr2.is_valid());
Naive_pl naive_pl2(arr2);
point_location_query(naive_pl2, source);
The ouput is: The point is located inside the UNBOUNDED face
The point is located inside the BOUNDED face
But it is the same point: source
If I use naive_pl for the second point_location_query again, like this:
everything is ok.
Any idea anybody ?
Thanks,
paul
- [cgal-discuss] Arrangement_2 IO problem, Paul Neugebauer, 06/24/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, Efi Fogel, 06/26/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, Paul Neugebauer, 06/26/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, David Keller, 06/28/2008
