- To:
- Subject: [cgal-discuss] Problem in 3D Triangulation
- Date: Tue, 24 Jun 2008 16:33:37 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:reply-to:to:subject:mime-version:content-type; b=w0sDMnVWfL6UZMi/0mBGWcUQh+MbpU6TDvUsvS4MBvpZv9qZ+LM5XLwjXzrscu6izC eHpz2uUQ8ytrcKCxl07mfZ2VkrQQ5fFKL/L0LUdv+u3tTraDdNZhzPob2+RohIp6tLGE XY1dCYpDp8ZTQEL4DMKI7R28hAUps4ORb0Vuk=
Dear all,
Recently I am using CGAL to compute 3D triangulation.
For some input data, the 3D triangulation does not work.
My simple test code is attached at the end of this email.
I am using Microsoft Visual Studio 2008 and CGAL-3.3.1.
The CGAL library is recompiled under VS2008.
My program always reports "Microsoft C++ exception: CGAL::Uncertain_conversion_exception at memory location ..." in debug mode.
In release mode, the program stops at some place, the call stack is attached after my sample code.
I have tried to use Exact_predicates_exact_constructions_kernel,
the problem is still there.
Does anyone know how to solve this problem ?
Thanks.
Yang Liu
INRIA - LORIA
#include <CGAL/Triangulation_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_3<K> Triangulation3D;
typedef Triangulation3D::Point Point3D;
#include <iostream>
#include <fstream>
int main()
Triangulation3D DT;
std::ifstream mout("c:\\test.txt");
for (int i = 0; i < 7; i++)
double x, y, z;
mout >> x >> y >> z;
DT.insert(Point3D(x,y,z));
mout.close();
return 0;
test.txt
5.2797039788822553e-002 -1.0000000000000000e+000 -8.5052301668333641e-001
-6.4775641845221166e-001 -1.0000000000000000e+000 8.8775770697145473e-001
4.9765656210897458e-001 -2.5474338749700953e-001 5.0567501274491111e-001
1.0000000000000000e+000 -1.0000000000000000e+000 1.2851343478562227e-001
1.0000000000000000e+000 -1.0000000000000000e+000 -5.0824290316902976e-001
-3.1646143449986469e-001 -1.0000000000000000e+000 1.0000000000000000e+000
-3.0282326636478069e-001 -8.4918673507225406e-001 1.0000000000000000e+000
Call stack in release mode
testcgal.exe!std::vector<short,std::allocator<short> >::_Ufill(short * _Ptr=0x005f74fc, unsigned int _Count=1, const short & _Val=8422) Line 1259 + 0x19 bytes
testcgal.exe!std::vector<short,std::allocator<short> >::_Insert_n() + 0x10d bytes
testcgal.exe!std::vector<short,std::allocator<short> >::insert() + 0x4e bytes
testcgal.exe!std::vector<short,std::allocator<short> >::push_back() + 0x62 bytes
testcgal.exe!CGAL::MP_Float::construct_from_builtin_fp_type<double>() + 0x144 bytes
testcgal.exe!CGAL::MP_Float::MP_Float() + 0x46 bytes
testcgal.exe!CGAL::Split_double<CGAL::MP_Float>::operator()(double d=0.12851343478562227, CGAL::MP_Float & num={...}, CGAL::MP_Float & den={...}) Line 70 + 0x13 bytes
testcgal.exe!CGAL::Quotient<CGAL::MP_Float>::Quotient<CGAL::MP_Float>(const double & n=0.12851343478562227) Line 94
testcgal.exe!CGAL::NT_converter<double,CGAL::Quotient<CGAL::MP_Float> >::operator()(const double & a=) Line 39 + 0xf bytes
testcgal.exe!CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >,CGAL::NT_converter<double,CGAL::Quotient<CGAL::MP_Float> > >::operator()(const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & a={...}) Line 225 + 0x13 bytes
testcgal.exe!CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> > >,CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<0> > >,CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >,CGAL::NT_converter<double,CGAL::Quotient<CGAL::MP_Float> > >,CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Simple_cartesian<CGAL::Interval_nt<0> >,CGAL::NT_converter<double,CGAL::Interval_nt<0> > >,1>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > >(const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & a1={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & a2={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & a3={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & a4={...}) Line 457 + 0xf bytes
testcgal.exe!CGAL::SF_Orientation_3<CGAL::Filtered_kernel_base<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >,CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > > >::operator()(const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & p={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & q={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & r={...}, const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & s={...}) Line 127
testcgal.exe!CGAL::TR3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS3<CGAL::T_vb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_vb3<void> >,CGAL::T_cb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_cb3<void> > > >::locate(const CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > & p={...}, CGAL::TR3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS3<CGAL::T_vb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_vb3<void> >,CGAL::T_cb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_cb3<void> > > >::Locate_type & lt=OUTSIDE_CONVEX_HULL, int & li=0, int & lj=2090193940, CGAL::TDS3<CGAL::T_vb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_vb3<void> >,CGAL::T_cb3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,CGAL::TDS_cb3<void> > >::Cell_handle start={...}) Line 1517 + 0x19 bytes
testcgal.exe!main() Line 21 + 0x47 bytes
testcgal.exe!_encode_pointer(void * ptr=0x00000000) Line 114 + 0x5 bytes
00393358()
kernel32.dll!7c817067()
[Frames below may be incorrect and/or missing, no symbols loaded for kernel32.dll]
- [cgal-discuss] Problem in 3D Triangulation, Yang Liu, 06/24/2008
- Re: [cgal-discuss] Problem in 3D Triangulation, Ashwin Nanjappa, 06/25/2008
- Re: [cgal-discuss] Problem in 3D Triangulation, Yang Liu, 06/25/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem in 3D Triangulation, Sylvain Pion, 06/25/2008
