- To:
- Subject: Re: [cgal-discuss] Arrangement_2 IO problem
- Date: Sat, 28 Jun 2008 19:20:57 +0200
Hi,
This seems to be the same bug I posted on 3/28/2008 on this list. Later on, I proposed a solution in the form of a patch which I attach to this message again. Hope it helps, please let me know.
By the way, @Efi Fogel: On 4/17/2008 I pointed out another issue in overlaying arrangements with partially equal curves. Did you in the meanwhile find the time to have a closer look at it? I'm still lost there. Thanks for your help.
Kind regards
David Keller
Paul Neugebauer wrote:
Yes, I think you are right. It is a writing or reading problem. As you can see this is from examples/Arrangement_2/io.cpp but modified. I have marked the little modification. I just try to write the arr2 to a file again. I always get a Segmentation fault (core dumped).
//! \file examples/Arrangement_2/io.cpp
// Using the arrangement I/O operators.
#include "arr_rational_nt.h"
#include <CGAL/Cartesian.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/IO/Arr_iostream.h>
#include <fstream>
#include "point_location_utils.h"
typedef CGAL::Cartesian<Number_type> Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel> Traits_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
int main ()
// Construct the arrangement.
Arrangement_2 arr;
construct_segments_arr (arr);
std::cout << "Writing an arrangement of size:" << std::endl
<< " V = " << arr.number_of_vertices()
<< ", E = " << arr.number_of_edges()
<< ", F = " << arr.number_of_faces() << std::endl;
// Write the arrangement to a file.
std::ofstream out_file ("arr_ex_io.dat");
out_file << arr;
out_file.close();
// Read the arrangement from the file.
Arrangement_2 arr2;
std::ifstream in_file ("arr_ex_io.dat");
in_file >> arr2;
in_file.close();
std::cout << "Read an arrangement of size:" << std::endl
<< " V = " << arr2.number_of_vertices()
<< ", E = " << arr2.number_of_edges()
<< ", F = " << arr2.number_of_faces() << std::endl;
//+++++++++++++++++++modified +++++++++++++++++++++++++
// Write the arrangement to a file2.
std::ofstream out_file2 ("arr_ex_io2.dat");
std::cout << "still ok" << std::endl;
out_file2 << arr2;
std::cout << "not ok" << std::endl;
out_file2.close();
return (0);
I hope this helps!
I use CGAL 3.3-2 from the ubuntu packages.
paul
Efi Fogel schrieb:
It's seems like a bug. Probably in the writing to or reading from a file. Can you confirm?
Hi list,
I have got a strange problem with the Arrangement_2 IO. Here is a part of my program:
Naive_pl naive_pl(arr);
point_location_query(naive_pl, source);
std::ofstream out_file("output/arr_io.dat");
Formatter formatter;
write(arr, out_file, formatter);
out_file.close();
// Read the arrangement from a file
std::ifstream in_file2("output/arr_io.dat");
Arrangement_2 arr2;
read(arr2, in_file2, formatter);
in_file2.close();
assert(arr2.is_valid());
Naive_pl naive_pl2(arr2);
point_location_query(naive_pl2, source);
The ouput is: The point is located inside the UNBOUNDED face
The point is located inside the BOUNDED face
But it is the same point: source
If I use naive_pl for the second point_location_query again, like this:
everything is ok.
Any idea anybody ?
Thanks,
paul
diff -Naur CGAL-3.3.1.orig/include/CGAL/Arr_accessor.h CGAL-3.3.1/include/CGAL/Arr_accessor.h --- CGAL-3.3.1.orig/include/CGAL/Arr_accessor.h 2007-08-25 21:01:33.000000000 +0200 +++ CGAL-3.3.1/include/CGAL/Arr_accessor.h 2008-04-06 17:34:08.000000000 +0200 @@ -1119,6 +1119,46 @@ { return (p_arr->dcel.new_isolated_vertex()); } + + /*! + * Set the bottom right vertex + */ + void set_bottom_right_fictitious_vertex( Dcel_vertex* vertex ) + { + p_arr->v_br = vertex; + } + + /*! + * Set the top right vertex + */ + void set_top_right_fictitious_vertex( Dcel_vertex* vertex ) + { + p_arr->v_tr = vertex; + } + + /*! + * Set the bottom left vertex + */ + void set_bottom_left_fictitious_vertex( Dcel_vertex* vertex ) + { + p_arr->v_bl = vertex; + } + + /*! + * Set the top left vertex + */ + void set_top_left_fictitious_vertex( Dcel_vertex* vertex ) + { + p_arr->v_tl = vertex; + } + + /*! Set the fictitious face of the arrangement. */ + void set_fictitious_face( Dcel_face* face ) + { + p_arr->un_face = face; + } + + //@} }; diff -Naur CGAL-3.3.1.orig/include/CGAL/IO/Arrangement_2_reader.h CGAL-3.3.1/include/CGAL/IO/Arrangement_2_reader.h --- CGAL-3.3.1.orig/include/CGAL/IO/Arrangement_2_reader.h 2007-08-25 21:01:33.000000000 +0200 +++ CGAL-3.3.1/include/CGAL/IO/Arrangement_2_reader.h 2008-04-06 21:05:15.000000000 +0200 @@ -123,6 +123,10 @@ MINUS_INFINITY); v_tr = m_arr_access.new_vertex_at_infinity (PLUS_INFINITY, PLUS_INFINITY); + m_arr_access.set_bottom_left_fictitious_vertex( v_bl ); + m_arr_access.set_top_left_fictitious_vertex( v_tl ); + m_arr_access.set_bottom_right_fictitious_vertex( v_br ); + m_arr_access.set_top_right_fictitious_vertex( v_tr ); // Read the DCEL vertices and store them in the vertices vector. formatter.read_vertices_begin(); @@ -276,6 +280,10 @@ void _read_face(Formatter& formatter) { formatter.read_face_begin(); + + // Read unbounded + bool ubd = formatter.read_size ("unbounded" ); + // Try reading the outer CCB of the face. formatter.read_outer_ccb_begin(); @@ -288,6 +296,7 @@ // Allocate the fictitious DCEL face. new_f = m_arr_access.new_face(); new_f->set_halfedge (NULL); + m_arr_access.set_fictitious_face( new_f ); } else { @@ -296,6 +305,7 @@ he = _read_ccb (formatter, new_f, outer_size, NULL); new_f->set_halfedge (he); } + new_f->set_unbounded( ubd ); formatter.read_outer_ccb_end(); // Read the holes inside the face. diff -Naur CGAL-3.3.1.orig/include/CGAL/IO/Arrangement_2_writer.h CGAL-3.3.1/include/CGAL/IO/Arrangement_2_writer.h --- CGAL-3.3.1.orig/include/CGAL/IO/Arrangement_2_writer.h 2007-08-25 21:01:33.000000000 +0200 +++ CGAL-3.3.1/include/CGAL/IO/Arrangement_2_writer.h 2008-04-06 21:02:45.000000000 +0200 @@ -219,6 +219,9 @@ formatter.write_face_begin(); + // Write unbounded + formatter.write_size ("unbounded", static_cast<int>( f->is_unbounded() ) ); + // Write the outer CCB. formatter.write_outer_ccb_begin(); if (f->is_fictitious()) diff -Naur CGAL-3.3.1.orig/include/CGAL/IO/Arr_text_formatter.h CGAL-3.3.1/include/CGAL/IO/Arr_text_formatter.h --- CGAL-3.3.1.orig/include/CGAL/IO/Arr_text_formatter.h 2007-08-25 21:01:33.000000000 +0200 +++ CGAL-3.3.1/include/CGAL/IO/Arr_text_formatter.h 2008-04-06 20:59:36.000000000 +0200 @@ -27,6 +27,7 @@ #include <CGAL/basic.h> #include <iostream> +#include <string> CGAL_BEGIN_NAMESPACE @@ -391,6 +392,10 @@ int val; in() >> val; + + // ignore blank after value + m_in->ignore(); + return (val); } @@ -479,8 +484,9 @@ { CGAL_assertion (m_in != NULL); - int c; - while ((c = m_in->get()) != EOF && c != '\n'); + std::string line; + std::getline( *m_in, line ); + return; } @@ -488,12 +494,15 @@ void _skip_comments () { CGAL_assertion (m_in != NULL); - - int c; - while ((c = m_in->get()) != EOF && c == '#') - _skip_until_EOL(); - m_in->putback (c); - + + std::string comment; + std::getline( *m_in, comment ); + if ( comment.empty() ) + return _skip_comments(); + int s = comment[0]; + if ( s == '\n' ) + return _skip_comments(); + CGAL_assertion ( s == '#' ); return; }
- [cgal-discuss] Arrangement_2 IO problem, Paul Neugebauer, 06/24/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, Efi Fogel, 06/26/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, Paul Neugebauer, 06/26/2008
- Re: [cgal-discuss] Arrangement_2 IO problem, David Keller, 06/28/2008
