cgal-discuss - Re : [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003
  • To:
  • Subject: Re : [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003
  • Date: Tue, 15 Jul 2008 13:21:24 +0000 (GMT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=w7SrvGkmbfx2Rj+LmTDSV9XCByS8QPQKqIhFO0tftokZZX6GZ+oVkoQaF52oTkzcTkzArQ5Gpbnqx21qgqUP+ctbPwFWmQbA1+ZomiiYFfXMNfU1nwFwO6R8YIdj2tMjkAY7sLy7D0U9WDcdfIKkjIbLI4k1PALuyy1N/VMfRU8=;
Hi,
I gave you all the error message shown in Visual Studio, i.e., "error result returned from 'cl.exe'."
Thanks
Hichem
----- Message d'origine ----
De : Laurent Rineau <>
À :
Envoyé le : Mardi, 15 Juillet 2008, 14h26mn 51s
Objet : Re: [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003
On Tuesday 15 July 2008 14:21:09 BBB HHH wrote:
> Hi,
> I have an error : "error result returned from 'cl.exe'." when i tried to
> compile some CGAL code that uses CGAL::do_intersect() with two objects of
> type CGAL::Polygon_2 as parameters.
> I tried changing several project options in Visual Studio 2003, but the
> error is persistant.
> Can some one helps me t resolve this problem ?
You could help us by quoting the error entirely. "error result" is not
sufficient.
Here is the FAQ entry about reporting a bug:
  http://www.cgal.org/FAQ.html#bug_reporting
which points to:
  http://www.cgal.org/bug_report.html
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Envoyé avec Yahoo! Mail.
Une boite mail plus intelligente.
