- To:
- Subject: Re: [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003
- Date: Tue, 15 Jul 2008 06:38:06 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=4xocxykEvSHM/BueikWbcy9L4bJVqeKK9lJjG7Ndi7qWgo619u2ZUc5+BNBmRmYWy0n00Wl60OfyrSM0utjuBSpQC3U/Lg8y+Z002lTl9a89HgR+bw0vLZ0hGrKpwcuwGHbUNICc1MMrKuqZwwVH3twUZl0UIw+3I2ThVCu6Oog=;
>I have an error : "error result returned from 'cl.exe'."
Did you install SP1 for 2003? Can you test with 2005?...
Mahmood Naderan
Mahmood Naderan
----- Original Message ----
To:
Sent: Tuesday, July 15, 2008 3:51:09 PM
Subject: [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003
Envoyé avec Yahoo! Mail.
Une boite mail plus intelligente.
To:
Hi,
I have an error : "error result returned from 'cl.exe'." when i tried to compile some CGAL code that uses CGAL::do_intersect() with two objects of type CGAL::Polygon_2 as parameters.
I tried changing several project options in Visual Studio 2003, but the error is persistant.
Can some one helps me t resolve this problem ?
Thanks in advance
Hichem
Thanks in advance
Hichem
- [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003, BBB HHH, 07/15/2008
- Re: [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003, Laurent Rineau, 07/15/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] A linker error when using CGAL::do_intersect() with VS 2003, Mahmood Naderan, 07/15/2008
