- To: <>
- Subject: Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm
- Date: Tue, 15 Jul 2008 17:09:39 -0300
- Organization: Geometry Factory
Hello Martin,
Indeed... this has been fixed shortly after 3.3.1 went out.Hello,
I guess, I found a bug in CGAL straight skeleton 2 algorithm.
I just tested it and the corrected algorithm (to be included in the next release) works fine in your case.
If you wish to evaluate the patched algorithm I can email you an executable that reads in a file listing the vertices of a polygon and outputs an .eps drawing with the specified offset (see the .eps attached corresponding to your report)
HTH
Fernando Cacciola
www.geometryfactory.com
report.dat.offset.eps
Description: PostScript document
- [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Martin Stumpf, 07/10/2008
- Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Fernando Cacciola, 07/15/2008
- Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Martin Stumpf, 07/16/2008
