- To:
- Subject: Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm
- Date: Wed, 16 Jul 2008 09:42:09 +0200 (CEST)
- Importance: Normal
Hello Fernando,
thanks for your answer. It would be nice, if you send me the executable.
Is there also a patch for the source code or do I have to wait for the
next release? What does your roadmap say about the next release?
Thanks + Best regards,
Martin
> Hello Martin,
>>> Hello,
>>> I guess, I found a bug in CGAL straight skeleton 2 algorithm.
> Indeed... this has been fixed shortly after 3.3.1 went out.
> I just tested it and the corrected algorithm (to be included in the next
> release) works fine in your case.
> If you wish to evaluate the patched algorithm I can email you an
> executable that
> reads in a file listing the vertices of a polygon and outputs an .eps
> drawing
> with the specified offset (see the .eps attached corresponding to your
> report)
> HTH
> Fernando Cacciola
> www.geometryfactory.com
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> | Z1 SecureMail Gateway Info - http://www.zertificon.com |
> | - Die Nachricht war weder verschluesselt noch digital unterschrieben |
- [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Martin Stumpf, 07/10/2008
- Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Fernando Cacciola, 07/15/2008
- Re: [cgal-discuss] Wrong offset from straight skeleton 2 algorithm, Martin Stumpf, 07/16/2008
