- To:
- Subject: Re: [cgal-discuss] Polyhedron_3 I/O problem
- Date: Wed, 16 Jul 2008 20:22:41 +0200
- Importance: Normal
Hi Joe,
that's odd. The file is OK and I'm also told that it is valid by
Polyhedron_3. My program looks something like the following:
typedef CGAL::Homogeneous<CGAL::Gmpz> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
int main()
Polyhedron_3 poly;
std::ifstream in("cube.off");
in >> poly;
std::cout << "valid " << poly.is_valid();
That works nicely
Peter
To:
Date: 07/16/2008 07:01PM
Subject: Re: [cgal-discuss] Polyhedron_3 I/O problemI tried Max's approach, it's not working...
Peter, please see the attached cube.off that I used in my test. It's just a simple cube object. When I read in this file, the polyhedron is not valid though I cannot see anything wrong with the data. The cube looks right in my viewer too, but just not valid.
JoeOn Wed, Jul 16, 2008 at 2:25 AM, Peter Hachenberger < > wrote:Hi Joe,
that sounds like unwanted behavior. Can you send me some example file and tell me what the difference is between how it looks like and how it should look like?
Peter-----"Joe C" wrote: -----To:From: "Joe C"
Date: 07/16/2008 01:56AM
cc: "Joe C"
Subject: [cgal-discuss] Polyhedron_3 I/O problemHi, everyone,
I am testing a simple I/O function of Polyhedron_3. I found that the output has different results from the input. Here is the pseudo code:
// a polyhedron
Polyhedron_3 poly;
// some construction work, not listed....
// test closeness and validity before output
poly.is_closed(); // true
poly.is_valid(); // true
// output
std::ofstream SaveFile("output.off");
SaveFile << poly;
SaveFile.close();
// read in output
poly.clear();
OpenFile.open("output.off");
OpenFile >> poly;
OpenFile.close();
// test closeness and validity after output
poly.is_valid(); // false, different from original one
Notice that the polyhedron "poly" after reading in the output is no longer valid.
Is this CGAL bug or am I missing something here ? My guess is that somehow it messed up because of some numerical problem. I am using Exact_predicates_exact_constructions_kernel.
P.S. if I read in some ".off" model into Polydedron_3, do I lose the original validity of the model as well?
Thanks.
Joe
cube.off
Description: Binary data
- [cgal-discuss] Polyhedron_3 I/O problem, Joe C, 07/16/2008
- Re: [?? Probable Spam] [cgal-discuss] Polyhedron_3 I/O problem, cgal_www, 07/16/2008
- Re: [cgal-discuss] Polyhedron_3 I/O problem, Peter Hachenberger, 07/16/2008
- Re: [cgal-discuss] Polyhedron_3 I/O problem, Joe C, 07/16/2008
