cgal-discuss - Re: [?? Probable Spam] [cgal-discuss] Polyhedron_3 I/O problem
  • To: "" <>
  • Subject: Re: [?? Probable Spam] [cgal-discuss] Polyhedron_3 I/O problem
  • Date: Wed, 16 Jul 2008 16:54:48 +0800
  • Organization: Max
Hello Joe
try
// a polyhedron
Polyhedron_3 poly;
// some construction work, not listed....
// test closeness and validity before output
poly.is_closed(); // true
poly.is_valid(); // true
// output
std::ofstream SaveFile("output.off");
SaveFile << poly;
SaveFile.close();
// read in output
Polyhedron_3 poly1;
OpenFile.open("output.off");
OpenFile >> poly1;
OpenFile.close();
// test closeness and validity after output
poly1.is_closed(); // true
poly1.is_valid(); // false, different from original one
I haven't tested the code.
B/Rgds
Max
----- Original Message ----
To:
Sent: 2008-07-16 07:57:09
Subject: [?? Probable Spam] [cgal-discuss] Polyhedron_3 I/O problem
Hi, everyone,
I am testing a simple I/O function of Polyhedron_3. I found that the output
has different results from the input. Here is the pseudo code:
// a polyhedron
Polyhedron_3 poly;
// output
SaveFile << poly;
SaveFile.close();
// read in output
poly.clear();
OpenFile >> poly;
OpenFile.close();
poly.is_valid(); // false, different from original one
Notice that the polyhedron "poly" after reading in the output is no longer
valid.
Is this CGAL bug or am I missing something here ? My guess is that somehow
it messed up because of some numerical problem. I am using
Exact_predicates_exact_constructions_kernel.
P.S. if I read in some ".off" model into Polydedron_3, do I lose the
original validity of the model as well?
Thanks.
Joe
