- To: <>
- Subject: RE: [cgal-discuss] Traversing the vicinity faces of a given vertex
- Date: Thu, 31 Jul 2008 10:18:45 +0100
Hi Andreas,
Thanks for the info. I want only continuous surface patch around a given
vertex, satisfying a geometric constraint. And the Polyhedron is
triangle-only. Any more ideas?
Regards
Xiaofan
________________________________
[mailto:]
Sent: Thu 7/31/2008 10:18
To:
Subject: Re: [cgal-discuss] Traversing the vicinity faces of a given vertex
Hello,
There is no such function. Also it is not cleasr to me if your radius
is on the surface or in the 3D space. In the latter case you could
have points which are far away on the surface but close in space.
Even if you are only intersted in those close on the surface, things
can be complicated if the faces of the polyhedron are not convex
andreas
Xiaofan Li wrote:
> Just to make this a bit more clear -- I want to traverse within a give
> radius R which can include more than 1 layer of the facets. So local
> circulator such as halfedge_around_facet_circulator won't work straightaway
> either.
> From: Xiaofan Li
> [mailto:]
> Sent: Thu 7/31/2008 03:17
> To:
> Subject: [cgal-discuss] Traversing the vicinity faces of a given vertex on
> a polyhedron
> Hi everybody,
> Just want to know what is the most efficient way to find out all facets (or
> vertices) within the vicinity (radius) r of a given vertex? I don't want to
> use global facets/vertex circulators as the mesh is quite large, but want
> to start from the known vertex where its adjacent halfedges and facets are
> known. But the question then becomes, how to implement a traverse algorithm
> to search around the given vertex? Does CGAL provide this functionality or
> does anyone of you could give me some hints on how to implement this?
> Thanks a lot in advance.
> Regards,
> Xiaofan
> Xiaofan Li
> Biomolecular Modeling Laboratory
> Cancer Research UK, London Research Institute
> <mailto:>
> Department of Biochemistry and Molecular Biology
> University College London
> <mailto:>
<<winmail.dat>>
- [cgal-discuss] Traversing the vicinity faces of a given vertex on a polyhedron, Xiaofan Li, 07/31/2008
- RE: [cgal-discuss] Traversing the vicinity faces of a given vertex on a polyhedron, Xiaofan Li, 07/31/2008
- Re: [cgal-discuss] Traversing the vicinity faces of a given vertex, Andreas Fabri, 07/31/2008
- RE: [cgal-discuss] Traversing the vicinity faces of a given vertex, Xiaofan Li, 07/31/2008
