- To: <>
- Subject: [cgal-discuss] failure case for boolean operation
- Date: Fri, 8 Aug 2008 15:33:33 +0100
Title: failure case for boolean operation
Hi All
I was trying out Boolean operations. I met a case where a sphere radius 5 at (5,0,0) centre is cut by a plane with equate x=5. It exits with this error message
** Gts:ERROR:(boolean.c:1563):???: assertion failed: (x != 0. || y != 0. || z != 0.)
The same operation works if I change the plane equation to x+y+z=5.
I don’t know the internals of GTS but Is there any reason why it does that?
Thanks
Sri
Scanned by iCritical for STFC.
- [cgal-discuss] failure case for boolean operation, Nagella, S (Srikanth), 08/08/2008
- Re: [cgal-discuss] failure case for boolean operation, Sylvain Pion, 08/08/2008
