cgal-discuss - Re: [cgal-discuss] Boundary of alphashapes
  • To:
  • Subject: Re: [cgal-discuss] Boundary of alphashapes
  • Date: Fri, 08 Aug 2008 15:48:24 +0200
But how can I write the boundaries into a file. I would like to have look on
the boundaries to be able to decide which is the best alpha for my set of
points.
andi
-------- Original-Nachricht --------
> Datum: Fri, 08 Aug 2008 15:41:45 +0200
> Von: Mariette Yvinec
> An:
> Betreff: Re: [cgal-discuss] Boundary of alphashapes
> Depending on the value you are going to choose for alpha,
> you can get a whole family of different alphashapes
> with different boundaries.
> I am not sure that one of them corresponds to
> what you are expecting
> wrote:
> > Hello Mariette,
> > you are right, there is no relation between alphashapes and shapefiles.
> > The only thing I want to do, is to write the boundaries which are
> defined by the set of points into a file.
> > Or am I totally wrong and alphashapes are not the right method to solve
> my problem.
> > Thanks
> > andi
> >> Datum: Fri, 08 Aug 2008 14:59:14 +0200
> >> An:
> >> From what I see in wikipedia
> >> there is no relationship between alphashapes and shape file...
> >> and I still don't get what shape you want to get
> >> Andi Jochem wrote:
> >>> Hello Mariette,
> >>> a shapefile is a popular geospatial vector data format for geographic
> >> information systems
> >>> (http://en.wikipedia.org/wiki/Shapefile)
> >>> As you already know, I am not very familiar with alphashapes, but
> maybe
> >> you can help me.
> >>> I am just looking for a method to get the shape, defined by a set of
> >> points (the "concave hull" , not the convex hull). After an intensiv
> google
> >> search, I found the CGAL library, installed it and tried to write a
> function
> >> using alpha_shapes_3.
> >>> My question is: How can I get, the shape which is defined by a set of
> >> points in file?
> >>> Thanks
> >>> Andi
> >>>> Datum: Fri, 08 Aug 2008 14:37:54 +0200
> >>>> An:
> >>>> I am rather familiar with Alpha_shape_3
> >>>> but I can't answer your questions
> >>>> because I do not understand them...
> >>>> In particular I don't know
> >>>> - what is a shapefile
> >>>> - nor which polygon you want to get out of alpha_shapes_3
> >>>> - nor what is a roof plane
> >>>> wrote:
> >>>>> Hello,
> >>>>> I wrote a function to get the alphashapes of a set of points, but
> how
> >>>> can I
> >>>>> transform this alphashapes in a polygon...???
> >>>>> Is it posssible to transform the created alphashape in a
> shapefile???
> >>>>> Is anybody familiar with alphashapes??
> >>>>> Thanks a lot.
> >>>>> andi
> >>>> Mariette Yvinec
> >>>> Geometrica project team
> >>>> INRIA Sophia-Antipolis
> >>>> You are currently subscribed to cgal-discuss.
> >>>> To unsubscribe or access the archives, go to
> >>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> >> Mariette Yvinec
> Mariette Yvinec
Psssst! Schon das coole Video vom GMX MultiMessenger gesehen?
Der Eine für Alle: http://www.gmx.net/de/go/messenger03
