- To: "cgal-discuss" <>
- Subject: Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
- Date: Mon, 11 Aug 2008 08:59:52 +0200
Hi!
>> How are the constructions filtered? Can you please give me an example?
>When you perform an orientation test for three lazy points
>it is first performed on the approximate points with double intervals.
>If this cannot been done the exact versions of the points are
>computed by applying the exact constructions of the DAG.
I thought an orientation test is a predicate not a construction? I
assumed that a construction ''computess'' a new geometric object like:
mySegment = dt.dual(myDelaunayFacet) (dual method of a Delaunay
triangulation).
What is the exact difference between a predicate and a construction?
Thank you!
Best regards,
,yours Thomas Zangl, Bakk.rer.soc.oec. -
- Freelancer - IT Consulting & Software Development -
- Student of Software Development-Economy (Master) -
- http://blog.tzis.net -
- Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 08/10/2008
- Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Andreas Fabri, 08/11/2008
- Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 08/11/2008
