cgal-discuss - Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
  • To:
  • Subject: Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
  • Date: Mon, 11 Aug 2008 05:34:48 -0700
Thomas Zangl - Home wrote:
Hi!
How are the constructions filtered? Can you please give me an example?
When you perform an orientation test for three lazy points
it is first performed on the approximate points with double intervals.
If this cannot been done the exact versions of the points are
computed by applying the exact constructions of the DAG.
I thought an orientation test is a predicate not a construction? I
assumed that a construction ''computess'' a new geometric object like:
mySegment = dt.dual(myDelaunayFacet) (dual method of a Delaunay
triangulation).
What is the exact difference between a predicate and a construction?
Thank you!
Best regards,
Hi Thomas,
Did you read "A Generic Lazy Evaluation Scheme for Exact Geometric
Computations"
Sylvain Pion and Andreas Fabri,
In Proc. 2nd Library-Centric Software Design, pages 75-84, Portland, Oregon,
2006.
ftp://ftp-sop.inria.fr/geometrica/pion/publis/lazy-kernel.pdf
andreas
