cgal-discuss - [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?
  • To:
  • Subject: [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?
  • Date: Wed, 17 Sep 2008 00:15:00 +0200 (CEST)
hi
general problem description:
I experience a basic problem with the triangulation method of CGAL. Id need a
2D delaunay triangulation of a domain. (constrained/confirmed is not important
at this stage ). CGAL does not obey the constraints of the domain boundary.
a more detailed view of the problem:
consider the following point set:
#: x y
1: 0 1
2: 0 2
3: 2 2
4: 2 0
5: 1 0
6: 1 1
and followed the wished connection list of the boundary of my PSLG:
1: 1 2
2: 2 3
3: 3 4
4: 4 5
5: 5 6
6: 6 1
The problem is that CGAL produces (by using the basic triangulation ) 5
triangles, where 4 of the 5 triangles are within the mentioned PSLG and the
fifth is outside, consisting of the following points:
wrong triangle: 1-6-5
or the points: 0 1 - 1 1 - 1 0
in other words: the meshing process generates a triangle outside my given
constraints.
my approach:
I am using a fairly simple meshing procedure, followed the important parts of
my code:
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
struct K : public CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Delaunay_mesh_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds> CDT;
cdt.insert_constraint(Point( 0, 1 ), Point( 0, 2 ));
cdt.insert_constraint(Point( 0, 2 ), Point( 2, 2 ));
cdt.insert_constraint(Point( 2, 2 ), Point( 2, 0 ));
cdt.insert_constraint(Point( 2, 0 ), Point( 1, 0 ));
cdt.insert_constraint(Point( 1, 0 ), Point( 1, 1 ));
cdt.insert_constraint(Point( 1, 1 ), Point( 0, 1 ));
assert(cdt.is_valid());
A constrain verification by the CDT::Finite_edge_iterator yields the correct
number of constrained edges:
int count = 0;
for (CDT::Finite_edges_iterator eit = cdt.finite_edges_begin(); eit !=
cdt.finite_edges_end(); ++eit)
if (cdt.is_constrained(*eit)) ++count;
std::cout << "constrained edges: " << count << std::endl;
--> 6 .. this output outlines, that the constraints are there, but not
recognized / obeyed as a boundary of the meshing domain.
Apparently I miss something serious here, but after reading the parts of "2D
Triangulations" and "2D Conforming Triangulations and Meshes" of the manual a
few times, I am not able to answer this on my own. I hope anybody would be so
kind and help me out.
Id greatly appreciate your time spent on this problem!
thanks in advance,
regards,
Josef Weinbub
