Re: [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?
- To:
- Subject: Re: [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?
- Date: Wed, 17 Sep 2008 00:40:35 +0200
in other words: the meshing process generates a triangle outside my given
constraints.
Hi,
In fact, you can see that it is not required that your constraint segments delimit a bounded domain, or are connected. It could as well consist of just one segment, and a few vertices.
The CGAL 2D constrained triangulation always returns a triangulation of the convex hull of the vertices, and the guarantee is that each constraint segment appears as edge of the triangulation.
In your case, your constraints bound a non convex domain, so you should expect this outer triangle.
Camille
- [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?, weinbub, 09/17/2008
- Re: [cgal-discuss] 2D_Constrained_Delaunay_triangulation - triangulation does not obey PSLG constraints ?, Camille Wormser, 09/17/2008
- Re: [cgal-discuss] 2D_Constrained_Delaunay_triangulation -, Josef Weinbub, 09/17/2008
- Re: [cgal-discuss] 2D_Constrained_Delaunay_triangulation -, Camille Wormser, 09/17/2008
