Re: [cgal-discuss] 2D mesh - how to enforce integrity of certain edges of a PSLG input
- To:
- Subject: Re: [cgal-discuss] 2D mesh - how to enforce integrity of certain edges of a PSLG input
- Date: Mon, 22 Sep 2008 23:54:20 +0200
On Monday 22 September 2008 22:38:52 M. Hazegh wrote:
> Hi everyone,
> Say I have 4 edges that define a rectangle. These edges are the
> constraints that will be used as input to create a 2D Constrained
> Delaunay Triangulation.
> I would like to make sure one of the edges will not have any nodes
> inserted on it (i.e. keeps it's integrity) during the triangulation
> process.
> Is it possible to enforce such constraints with CGAL?
If you use a Constrained_Delaunay_triangulation_2, no vertex will be inserted
in your constrained edges. If you want a quality mesh, you need to insert
Steiner vertices at least in edges that do not fullfill the Delaunay
criteria. There is no way to workaround that behavior of Mesh_2 easily.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] 2D mesh - how to enforce integrity of certain edges of a PSLG input, M. Hazegh, 09/22/2008
- Re: [cgal-discuss] 2D mesh - how to enforce integrity of certain edges of a PSLG input, Laurent Rineau, 09/22/2008
- Re: [cgal-discuss] 2D mesh - how to enforce integrity of certain edges of a PSLG input, M. Hazegh, 09/23/2008
