- To:
- Subject: [cgal-discuss] Numbertypes for convex hulls
- Date: Tue, 23 Sep 2008 12:44:38 +0200
Hi all,
After triangulating a set of points using Delaunay, I run through the list of
points to get the dual of each incident cell. I do that for each point in the
triangulation and construct (using convex_hull_3) a polyhedron of these
dual-points. This works great if I use Gmpz as a number type but fails if I
change the number type to double (by just changeing the typedef).
CGAL error: postcondition violation!
Expr: is_strongly_convex_3(P, traits)
File: /usr/local/src/CGAL-3.3.1/include/CGAL/convex_hull_3.h
Line: 468
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Aborted
How come the exact same code works for Gmpz and not for doubles?
Thanks for any tips,
Jens Becker
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
- [cgal-discuss] In 3D polyhedra Class.., calvin_cw, 09/15/2008
- Re: [cgal-discuss] In 3D polyhedra Class.., calvin_cw, 09/16/2008
- [cgal-discuss] Numbertypes for convex hulls, Jens K. Becker, 09/23/2008
- Re: [cgal-discuss] Numbertypes for convex hulls, Bernd Gaertner, 09/23/2008
