- To:
- Subject: [cgal-discuss] Problem with 3D Surface Mesh Generation
- Date: Fri, 3 Oct 2008 21:47:02 +0800 (CST)
Hi All,
To generate a surface, I have to construct a surface as a parameter for the make_surface_mesh function.
In the example "examples/Surface_mesher/mesh_an_implicit_function.cpp". It use a "sphere_function" to construct the surface, I think I haven't got the exact meaning of doing this.
What's more, I have a set of points describing someone's face, so what can I do if I want to get the mesh of this face.
Your inputs are appreciated.
Thanks & Regards,
Gu ShengFeng.
Gu ShengFeng.
- [cgal-discuss] Problem with 3D Surface Mesh Generation, gsfjay, 10/03/2008
- Re: [cgal-discuss] Problem with 3D Surface Mesh Generation, Laurent Rineau, 10/03/2008
- Re:Re: [cgal-discuss] Problem with 3D Surface Mesh Generation, gsfjay, 10/04/2008
