- To:
- Subject: Re: [cgal-discuss] Problem with 3D Surface Mesh Generation
- Date: Fri, 3 Oct 2008 16:02:07 +0200
On Friday 03 October 2008 15:47:02 gsfjay wrote:
> Hi All,
> To generate a surface, I have to construct a surface as a parameter for
> the make_surface_mesh function. In the example
> "examples/Surface_mesher/mesh_an_implicit_function.cpp". It use a
> "sphere_function" to construct the surface, I think I haven't got the exact
> meaning of doing this. What's more, I have a set of points describing
> someone's face, so what can I do if I want to get the mesh of this face.
What you need is a reconstruction algorithm, which produces a surface mesh
from a set of points, and not a surface mesh generator.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Problem with 3D Surface Mesh Generation, gsfjay, 10/03/2008
- Re: [cgal-discuss] Problem with 3D Surface Mesh Generation, Laurent Rineau, 10/03/2008
- Re:Re: [cgal-discuss] Problem with 3D Surface Mesh Generation, gsfjay, 10/04/2008
