- To:
- Subject: Re: [cgal-discuss] Delaunay Triangulation
- Date: Fri, 3 Oct 2008 12:59:59 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=CmBJ+U9DPqINwaRM0apBgTr+wLUzJ45MvzLb3b0Y1LaOSnmJbGg0KB6qewCMZ+0Jld wtQXiBvFu04Lxur9BOh8eOt7Q8x8bpQRMgdd4LrTHd+lxqCOKaPC/QY/lSK8stDSMH+L UXOVUF8mVaXHnDCOdfNaEi/ueY+LWRJfK3qTs=
You need to use iterators. Here is an example from the manual that
iterates through vertices.
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_25.4.2
-Ramin
On Fri, Oct 3, 2008 at 12:05 PM, Andreas Fabri
wrote:
> Dennis Endt wrote:
>> Hi,
>> I installed CGAL a few days ago about to use the 3d delaunay function.
>> So I followed the example and create an Delaunay Trinagulation Object:
>> Triangulation T;
>> So I inserted my Points and all works fine.
>> But how can I acces the points and the faces in my Object for manually
>> inserting them to another object?
>> Can someone give me an short example plz?
>> Greets,
>> Dennis
> It might help to read the manual.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Delaunay v/s Voronoi, (continued)
- Re: [cgal-discuss] Delaunay v/s Voronoi, Monique Teillaud, 10/06/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Steve Chan, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, daniel . duque, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Laurent Rineau, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Chaman Singh Verma, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Daniel Duque Campayo, 10/06/2008
- [cgal-discuss] Delaunay Triangulation, Dennis Endt, 10/03/2008
- Re: [cgal-discuss] Delaunay Triangulation, Andreas Fabri, 10/03/2008
- Re: [cgal-discuss] Delaunay Triangulation, M. Hazegh, 10/03/2008
- Re: [cgal-discuss] Delaunay Triangulation, Dennis Endt, 10/04/2008
