- To:
- Subject: Re: [cgal-discuss] Delaunay v/s Voronoi
- Date: Fri, 3 Oct 2008 23:39:34 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=Nsi3ydOneryetR7+n/Aw95DA4KjVML1wXN+LJiSI7xdLV4FT2D0zkbza4j2vRw8HDK EefeayOpgS8AO9RQeWVKTogSGUCzSCftV15qlwnLIxzF2hod3/oTr9niM5TExWjcGIfG JZ4JG7fwJXuETjEnVU2Gu4WJwsD5p0vOLOk5M=
Hello,
So which method is easier to implement ? Voronoi or Delaunay
csv
csv
On Fri, Oct 3, 2008 at 6:36 PM, Olivier Devillers <> wrote:
Delaunay and Voronoi are two point of view for the same object
I have one fundamental doubt. Delaunay triangulation and Voronoi Diagrams are dual to each other.
thus the complexity is exactly the same (since it is the same stuff)
implementation point of view, which one has less complexity ?
- [cgal-discuss] Delaunay v/s Voronoi, Chaman Singh Verma, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Olivier Devillers, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Chaman Singh Verma, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Sylvain Pion, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Monique Teillaud, 10/06/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Steve Chan, 10/03/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Delaunay v/s Voronoi, daniel . duque, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Laurent Rineau, 10/03/2008
- Re: [cgal-discuss] Delaunay v/s Voronoi, Daniel Duque Campayo, 10/06/2008
- [cgal-discuss] Delaunay Triangulation, Dennis Endt, 10/03/2008
