- To:
- Subject: Re: [cgal-discuss] CGAL & QT
- Date: Tue, 14 Oct 2008 23:03:28 +0200
On Tuesday 14 October 2008 22:52:00
wrote:
> Is there a version inconsistency between your library CGALQt-vc80-mt-gd.lib
> and the QT library qt-mt3.lib ? What shall I do to obtain correct linking ?
The answer is in your own message:
> I am working with following versions:
> QT 3.3.7: No 3.x versions available from Trolltech, I took unofficial
> version from http://sourceforge.net --> example projects work well
> CGAL 3.3.1 --> example projects without QT work well
> BOOST 1.36.0
Your unofficial version is not binary compatible with the commercial version
of Qt-3.3.x, which was used to compile CGALQt-vc80-mt-gd.lib. You need to
recompile that library with your version of Qt.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] CGAL & QT, stephan.wich, 10/14/2008
- Re: [cgal-discuss] CGAL & QT, Laurent Rineau, 10/14/2008
- [cgal-discuss] Errors when rebuilding CGAL, jqzhang, 10/15/2008
- Re: [cgal-discuss] Errors when rebuilding CGAL, Laurent Rineau, 10/15/2008
- Re: [cgal-discuss] Errors when rebuilding CGAL, jqzhang, 10/15/2008
