- To:
- Subject: Re: [cgal-discuss] Errors when rebuilding CGAL
- Date: Wed, 15 Oct 2008 09:07:14 +0200
On Wednesday 15 October 2008 07:14:27 jqzhang wrote:
> Hi,
> After installing CGAL and Qt3.3.4, I rebuilded CGAL in vs.net 2003
> successfully. But in vs.net 2005, rebuilding CGAL leaded to some errors as
> following: -------------
> Error 113 Could not delete file
> 'e:\xp\work\CGAL-3.3.1\lib\cgalpdb-vc80-mt-gd.pdb'. Make sure that the file
> is not open by another process and is not write-protected. CGALPDB
> Error 115 Could not delete file
> 'e:\xp\work\CGAL-3.3.1\lib\CGALPDB-vc80-mt-gd.idb'. Make sure that the file
> What's the reson of it?
The error says it: "e:\xp\work\CGAL-3.3.1\lib\cgalpdb-vc80-mt-gd.pdb is left
open by another process."
Maybe you have launched two Visual Studio process on the same project.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] CGAL & QT, stephan.wich, 10/14/2008
- Re: [cgal-discuss] CGAL & QT, Laurent Rineau, 10/14/2008
- [cgal-discuss] Errors when rebuilding CGAL, jqzhang, 10/15/2008
- Re: [cgal-discuss] Errors when rebuilding CGAL, Laurent Rineau, 10/15/2008
- Re: [cgal-discuss] Errors when rebuilding CGAL, jqzhang, 10/15/2008
