- To:
- Subject: Re: [cgal-discuss] Re: Flipping inside a triangulation
- Date: Wed, 15 Oct 2008 12:41:08 +0200
Hi Daniel
I probably read your messages too quickly, I had thought the flip was working but that you were getting an invalid triangulation.
I had not understood it was a precondition that was telling you this, otherwise I would have given the answer (I even checked in the code that the precondition was actually coded...)
good you finally found the solution!
Daniel Duque Campayo wrote:
Hello,
For the record, I have found the answer to my question.
T.flip(f,indx);
You cannot flip just any pair of adjacent triangles: they have to form a convex object!
This is precisely what the precondition error was telling me (as soon as I realized "orientation" meant position of a point relative to a line, not triangle orientation). This makes sense, since for my terrain such a forbidden flip would create a two-valued (folded) terrain, not quite what one wants.
Best,
Daniel
- [cgal-discuss] Re: Flipping inside a triangulation, daniel . duque, 10/13/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Re: Flipping inside a triangulation, daniel . duque, 10/13/2008
- Re: [cgal-discuss] Re: Flipping inside a triangulation, Daniel Duque Campayo, 10/15/2008
- Re: [cgal-discuss] Re: Flipping inside a triangulation, Monique Teillaud, 10/15/2008
