cgal-discuss - Re: [cgal-discuss] Minimum distance of a Point_3 from a Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Minimum distance of a Point_3 from a Polyhedron
  • Date: Mon, 20 Oct 2008 20:59:51 +0200
  • Organization: INRIA
hi Atul,
I think the feature is not yet in CGAL - but I could provide you with hints about how to solve this.
first let's try reformulating your problem:
given a polyhedron (let's assume non self-intersecting and watertight)
and a query point P, you want to know
- if P lies inside or outside the polyhedron.
- the closest distance form P to the polyhedron.
is this right?
Pierre
http://www-sop.inria.fr/members/Pierre.Alliez/
Atul Thakur a écrit :
Hi all:
I have a Polyhedron_3 and Point_3 and need to find out if the point lies "on the" polyhedron or not <the answer should be true if the point lies on the surface or very near to it, should be false if it lies deep within or totally outside of polyhedron>.
I think one way of doing this is to determine the distance of the point from each facet plane along its normal of the Polyhedron and then seeing if any of the distance is less than a minimum bound value (say 1e-5). Is this the right way or there exists some neat elegant function to do this check <being a newbie, scanning 3500 pages of manual looks daunting :)>? I saw some functions Polytope distance* but haven't quite understood(may be unrelated).
Any pointers would be really helpful.
sincerely,
-Atul
