cgal-discuss - Re: [cgal-discuss] Minimum distance of a Point_3 from a Polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Minimum distance of a Point_3 from a Polyhedron
  • Date: Tue, 21 Oct 2008 10:32:10 +0200
Atul Thakur wrote:
I generated the Polyhedron by creating convex hull of my geometry as follows.
If the polytope is convex, you can indeed use Polytope_distance_d. For this, you don't even need the polytope itself, you just need a set of points, and the package will compute the closest point in their convex hull from a given point (or polytope). If the point is on or inside the hull, you also get a subset of at most 4 points whose convex hull contains it, so you can test "how interior" the point is. Feel free to contact me in private about details (I'm one of the authors of the Polytope_distance_d package).
Best,
Bernd Gaertner.
