- To:
- Subject: [cgal-discuss] Possible bug in templating of general_polygon_set_2.h
- Date: Tue, 21 Oct 2008 15:05:27 -0400
Hi,
Looking at CGAL/General_polygon_set_2.h line 58, in CGAL 3.3.1 I see what appears to be an omission:
The definition of "self" is templated _without_ the Dcel_ template parameter.
This means that the expected "other" GPS for a difference on self operation (e.g. gps.difference(other)) is a GPS with the default dcel, EVEN if I have instantiated the GPS with a custom dcel.
In my case, this is exactly my situation..all of my GPS's are templated with custom DCELs...adding Dcel_ to the self typedef fixes the compile problems.
(This is definitely a weird use of the general-polygon-set class! :-)
I can file a bug or send a modified source file if needed/desired.
This is the SVN info for the version of the file I have:
// $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.3-branch/Boolean_set_operations_2/include/CGAL/General_polygon_set_2.h $
// $Id: General_polygon_set_2.h 37178 2007-03-17 08:50:51Z afabri $ $Date: 2007-03-17 09:50:51 +0100 (Sat, 17 Mar 2007) $
Thanks!!
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Possible bug in templating of general_polygon_set_2.h, Ben Supnik, 10/21/2008
