cgal-discuss - Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2()
  • To:
  • Subject: Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2()
  • Date: Tue, 21 Oct 2008 21:21:25 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=R3gSFkn7IOqZiRbH6y1TDQTQUZOQC8Svi0yd1rvQKpBP68oPI++pY+tVkvuTS7FG5f A3z3VsrXTz9dnFZM9t2WGNwt7I3xmEHwZFSD5Kow/jRHFnF/zQw1RV1s6sA1gQb+OFYH ceh3LLmC9kIR+PDaJn6QfX+Mnavwli4Z50Gws=
Mariette and Laurent, I wanted to thank you for your help.
I finished the implementation and it works as long as the boundary
constraints are subdivided like usual.
-Ramin
On Thu, Oct 16, 2008 at 12:03 PM, Laurent Rineau
wrote:
> On Thursday 16 October 2008 17:49:30 M. Hazegh wrote:
>> Is there a paper, technical report or a webpage that explains the
>> algorithm used in CGAL::refine_Delaunay_mesh_2?
> Yes. The papers are cited in the manual. See
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher/Chapter_main.html#Section_35.5
> The paper you look for [RY06] has been published meanwhile. It can be found
> via Google Scholar:
> http://scholar.google.com/scholar?q=A+generic+software+design+for+Delaunay+refinement+meshing
> If you have feedback about that paper, please email-me.
> Best regards,
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
