cgal-discuss - Re: [cgal-discuss] Mesh Refinement for Polyhera surfaces
  • To:
  • Subject: Re: [cgal-discuss] Mesh Refinement for Polyhera surfaces
  • Date: Thu, 23 Oct 2008 08:33:46 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=gTEJcDGTItHvjMSK+epjA5NcpSiifYlXiw9d3ODh0Kt8WnC5cYitopIL35Sz5+elic YZWwW2oh5Ep/H2bliteIBvnu3OOr+F0Gcpt/r7f+aR0/+2VMrnSEZfOCb3fRnvLcuXwk /PTiSQ89p6EQPTfu4ZCKWw5SeN9EUh1OY2VXg=
hi Pierre,
I was going to implement one myself but now I can probably base my
code on the existing one. I'd appreciate it if you send me the code.
If you also have an little test code to debug it, I'd like to have
that too. Since it's not documented, that will help me to understand
how to use it.
Thank you,
-Ramin
On Thu, Oct 23, 2008 at 3:48 AM, Pierre Alliez
wrote:
> hi Ramin,
> to complete Laurent's answer - our current implementation computes
> efficiently the intersection between a triangle surface mesh a
> ray/line/segment. inspired by teh OPCODE collision detection library - we
> have implemented a CGAL version (shorter and very simple to use).
> should you want to try the code before the release and sending us feedback -
> just let me know.
> M. Hazegh a écrit :
>> Hi everyone,
>> I could not find a mesh refinement package for Polyhedra surfaces in
>> CGAL, I mean:
>> input:(3D polyhedra surface) --> output:(3D surface mesh)
>> I was wondering is such package exists or if someone has already
>> implemented this?
>> Thanks,
>> -Ramin
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
