cgal-discuss - Re: [cgal-discuss] Mesh Refinement for Polyhera surfaces
  • To:
  • Subject: Re: [cgal-discuss] Mesh Refinement for Polyhera surfaces
  • Date: Thu, 23 Oct 2008 08:37:52 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=xkKiePeKlLqYkV3VEvAXWYld0y4MTQhhmDBspv8JmvixewwLtTDdEq3J0COzpeHWJu CaLee6u59O6bj1vnVQzWi/chBgAmg3aCA9gtsEookZ1AEjIMQEK7TzyBizgFLJcPOeaN G/UoY3n3/OfW2NmuX1LdhOSk5MjTT5mzrz4xM=
Thank you Andreas,
Yes, I want to do re-meshing and not subdivision.
As far as I understand, subdivion changes the shape of the original
input and that's not what I want.
-Ramin
On Thu, Oct 23, 2008 at 4:05 AM, Andreas Fabri
wrote:
> M. Hazegh wrote:
>> Hi everyone,
>> I could not find a mesh refinement package for Polyhedra surfaces in
>> CGAL, I mean:
>> input:(3D polyhedra surface) --> output:(3D surface mesh)
>> I was wondering is such package exists or if someone has already
>> implemented this?
>> Thanks,
>> -Ramin
> Hi Ramin,
> Note that Laurent and Pierre apparently understood that you want
> to do remeshing.
> In case you mean mesh subdivision you might have a look here:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Subdivision_method_3/Chapter_main.html
> Best regards,
> andreas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
