- To:
- Subject: Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3
- Date: Wed, 29 Oct 2008 11:35:27 +0100
Andreas Fabri wrote:
Nizar Khalifa Sallem wrote:Not really but trying not to make it bug from the beginning :)
Hi,
Just to make sure on how to use Trinagulation_cell_base_with_info_3.
Here it is my code snippet, is it Ok or have I missed something (I didn't found example on how to use Trinagulation_cell_base_with_info_3 so I tried with the example on Trinagulation_vertex_base_with_info_3) ?
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Triangulation_vertex_base_3<Kernel> Vb;
typedef CGAL::Triangulation_cell_base_with_info_3<ExtraBaseAttributes, Kernel> ImprovedCell;
typedef CGAL::Triangulation_data_structure_3<Vb, ImprovedCell> Tds;
typedef CGAL::Delaunay_triangulation_3<Kernel, Tds> Delaunay;
Thanks
Hi Nizar,
It looks good to me. Did you encounter any problems with this?
andreas
- [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Laurent Rineau, 10/29/2008
- [cgal-discuss] access facets from cell iterator, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Daniel Duque Campayo, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Laurent Rineau, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Andreas Fabri, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Nizar Khalifa Sallem, 10/29/2008
