- To:
- Subject: [cgal-discuss] access facets from cell iterator
- Date: Wed, 29 Oct 2008 11:42:35 +0100
Another question from a CGAL beginner.
As I understood cells_iterator can be converted to cell_handler.
And a Facet is a pair<cell_handler, int> but does it provide constructor?
In other words can I acces facets of a cell this way (I didn't use facets_iterator since I need some information stored in the cell):
Delaunay::Finite_cells_iterator cell;
for (cell = Delaunay.finite_cells_begin(); cell != Delaunay.finite_cells_end(); cell++){
for (int i=0, i<4, ++i){
Facet f = Facet(cell, i);
or have I to write something like Facet f = std::make_pair(cell, i) ?
or is there an accessor like this Facet f = cell->facet(i) ?
Thanks
- [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Laurent Rineau, 10/29/2008
- [cgal-discuss] access facets from cell iterator, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Daniel Duque Campayo, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Laurent Rineau, 10/29/2008
- Re: [cgal-discuss] access facets from cell iterator, Nizar Khalifa Sallem, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Andreas Fabri, 10/29/2008
- Re: [cgal-discuss] use of Trinagulation_cell_base_with_info_3, Nizar Khalifa Sallem, 10/29/2008
