- To:
- Subject: Re: [cgal-discuss] create a new Triangulation_data_structure
- Date: Fri, 31 Oct 2008 10:42:34 +0100
I've already looked to Triangulation and Triangulation_data_structure but
Trangulation_data_structure is only parametrized with Cell_base and
Vertex_base and I need one that could also use some "Facet_base" so
deriving a new one from it could it be the right answer given that I still
want to use the other structures like Cell_hendle, Vertex_handle, etc.
There is no explicit Facet in the Triangulation data structure.
a Facet is a pair Cell_handle , index, where the index indicates which facet of the Cell you are interested in.
If you want to add an information in the facet, you have to add is in both cells that share that facet.
- [cgal-discuss] create a new Triangulation_data_structure, nksallem, 10/30/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Monique Teillaud, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, nksallem, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Olivier Devillers, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Mariette Yvinec, 10/31/2008
