- To:
- Subject: Re: [cgal-discuss] create a new Triangulation_data_structure
- Date: Fri, 31 Oct 2008 11:18:09 +0100 (CET)
- Importance: Normal
>> I've already looked to Triangulation and Triangulation_data_structure
>> but
>> Trangulation_data_structure is only parametrized with Cell_base and
>> Vertex_base and I need one that could also use some "Facet_base" so
>> deriving a new one from it could it be the right answer given that I
>> still
>> want to use the other structures like Cell_hendle, Vertex_handle, etc.
> There is no explicit Facet in the Triangulation data structure.
> a Facet is a pair Cell_handle , index, where the index indicates which
> facet of the Cell you are interested in.
> If you want to add an information in the facet, you have to add is in
> both cells that share that facet.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
That's exactly the problem. I want to add an explicit Facet structure to
the CGAL Triangulation_data_structure. And reading the article I mentioned
this should be done in a new Triangulation_data_structure class.
What I am asking for is how this class should be implement.
Best,
Nizar
- [cgal-discuss] create a new Triangulation_data_structure, nksallem, 10/30/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Monique Teillaud, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, nksallem, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Olivier Devillers, 10/31/2008
- Re: [cgal-discuss] create a new Triangulation_data_structure, Mariette Yvinec, 10/31/2008
