- To:
- Subject: Re: [cgal-discuss] stack flow of "Triangulation_3.incident_vertices(
- Date: Wed, 12 Nov 2008 18:01:52 +0100
Hello,
I just had a look at the code. The problem is that it calls
incident_cells, which is implemented recursively, and for a
vertex with many incident cells, as in your case the infinite
vertex, the stack is full.
We have to put it on our todo list. A temporary solution
might be to increase the stack size. I think for VC++ you
should use the linker command /STACK
http://msdn.microsoft.com/en-us/library/8cxs58a6(VS.80).aspx
Best regards,
andreas
Shuchu wrote:
Hi, all,
Why the operation "Triangulation_3.incident_vertices( )" show different results when in different compiler?
In my code , a CGAL::Triangulation_3 is built by using the method in "<CGAL/Triangulation_incremental_builder_3.h> " .
I try to find all vertices that incident to the infinite vertex. the code is as follow:
CGAL::Triangulation_3<> original_tet; ........
std::vector<Vertex_handle> vertices_incident_infinite;
Vertex_handle infinite_p = original_tet.infinite_vertex();
original_tet.incident_vertices( infinite_p , std::back_inserter( vertices_incident_infinite));
this part of code is working fine under the GCC compiler ( cygwin-gcc).
but in Vc2005, when debugging, the debugger throw an exception and say "stack overflow" at " original_tet.incident_vertices().."
like: " Unhandled exception at 0x00424ce9 in ****.exe: 0xC00000FD: Stack overflow."
Should I be careful when using this operation under VC2005?
Best Regards
Han shuchu
- [cgal-discuss] stack flow of "Triangulation_3.incident_vertices( )" when using in VC2005, Shuchu, 11/12/2008
- Re: [cgal-discuss] stack flow of "Triangulation_3.incident_vertices(, Andreas Fabri, 11/12/2008
- Re: [cgal-discuss] stack flow of "Triangulation_3.incident_vertices(, Shuchu, 11/13/2008
- Re: [cgal-discuss] stack flow of, Camille . Wormser, 11/18/2008
