- To:
- Subject: Re: [cgal-discuss] stack flow of
- Date: Tue, 18 Nov 2008 13:18:35 +0100 (CET)
- Importance: Normal
> this part of code is working fine under the GCC compiler ( cygwin-gcc).
> but in Vc2005, when debugging, the debugger throw an exception and
> say "stack overflow" at " original_tet.incident_vertices().."
> like: " Unhandled exception at 0x00424ce9 in ****.exe: 0xC00000FD: Stack
> overflow."
> Should I be careful when using this operation under VC2005?
This will not happen anymore with the next release of CGAL (CGAL-3.4).
Camille
- [cgal-discuss] stack flow of "Triangulation_3.incident_vertices( )" when using in VC2005, Shuchu, 11/12/2008
- Re: [cgal-discuss] stack flow of "Triangulation_3.incident_vertices(, Andreas Fabri, 11/12/2008
- Re: [cgal-discuss] stack flow of "Triangulation_3.incident_vertices(, Shuchu, 11/13/2008
- Re: [cgal-discuss] stack flow of, Camille . Wormser, 11/18/2008
