cgal-discuss - Re: [cgal-discuss] Comparing polygons
  • To:
  • Subject: Re: [cgal-discuss] Comparing polygons
  • Date: Tue, 18 Nov 2008 09:54:16 +0100
Roger House wrote:
Is there a CGAL function which can compare two polygons and determine if they are the same even when the order of the vertices may differ?
The order cannot differ that much. There can be a cyclic shift and it
can be clockwise or counterclockwise oriented.
The cyclic shift is already taken care of by CGAL. Let me copy paste
from the manual.
template <class Traits, class Container1, class Container2>
bool Polygon_2<Traits,Container1> p1 == Polygon_2<Traits,Container2> p2
Test for equality: two polygons are equal iff there exists a
cyclic
permutation of the vertices of p2 such that they are equal to
the
vertices of p1. Note that the template argument Container of
p1 and p2
may be different.
So it resumes to first check their size, then orient them both the same
way
if(p1.orientation() != p2.orientation()){
p2.reverse_orientation();
Is there a similar function which compares polygons with holes and which can figure out if two polygons are the same even if the holes appear in a different order?
Finding the lexicographically smallest vertex of each polygon should
help to pair them up.
best regards,
andreas
Roger House
