cgal-discuss - RE: [cgal-discuss] Triangulation to Polyhedron
  • To: cgal <>
  • Subject: RE: [cgal-discuss] Triangulation to Polyhedron
  • Date: Wed, 19 Nov 2008 20:09:45 +0000
  • Importance: Normal
I have a Delaunay_triangulation_3 and I want to convert it into a Polyhedron_3 data structure.
Ideally, I would only convert the convex hull (with no interior edges) of the triangulation to the polyhedron. I sent another mail about this problem, but I sent a new one as this was a more specific question.
Looks like I didn't take a good look at the convex hull example I have here:
CGAL::convex_hull_3(points.begin(), points.end(), ch_object);
CGAL::assign(polyhedron, ch_object);
I was hoping I could assign the entire triangulation to a polyhedron, and then use the polyhedron structure to delete interior edges?
> Date: Wed, 19 Nov 2008 20:59:15 +0100
> From:
> To:
> Subject: Re: [cgal-discuss] Triangulation to Polyhedron
> wrote:
> > Hi,
> > How do you convert a Delaunay_triangulation_3 object to a Polyhedron_3
> > object?
> To me it is already not clear what of the Delaunay triangulation you
> want to convert. The convex hull?
> > I tried to use CGAL::assign(), but it didn't work.
> assign operates on CGAL::Object which is a wrapper for whatsover type T
> and what assign does is unpacking whatever is in the object if the
> type of what is inside is identical to what you want to assign to.
> T t;
> Object o = make_object(t);
> Q q;
> T t2;
> bool b1 = assign(q,o); // b1 == false because typeof(t) != typeof(t)
> bool b2 = assign(t2, o); // b2 == true because typeof(t) == typeof(t2)
> All these words just to tell you that assign is not a any-to-any conversion
> tool.
> andreas
> > Thank you.
> > Alle fun stuff van Messenger nu verzameld op één coole site! Windows
> > Live Messenger <http://www.messengerbillboard.be/nl>
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Weer helemaal in het nieuw! Hotmail…
