- To: cgal <>
- Subject: RE: [cgal-discuss] Triangulation to Polyhedron
- Date: Thu, 20 Nov 2008 22:12:10 +0000
- Importance: Normal
Hi, I took a look at the incremental builder like you suggested. I was hoping I could build a polyhedron out of just the boundary faces of a delaunay triangulation. Here is what I came up with: My construction code is as follows: first add all vertices, then using a vector of triangles (indices to the vertices, computed earlier) add them as facets to the polyhedron. The data is contained like this: struct triangle { int indexA, indexB, indexC; }; std::vector<Point> m_vertices; // all the vertices of the polyhedron/triangulation std::vector<triangle> m_triangles; // contains references to the vertices in m_vertices I tested this with some debug data: one polyhedron consisting of 4 and another one with 5 vertices. I worked out the triangle vertex order on paper, and this produced correct results. I also fed the output of qhull to this code (9 vertices), and it too produced correct results. So I believe this part of my code is correct. void operator() (HDS& hds) { CGAL::Polyhedron_incremental_builder_3<HDS> B(hds, true); B.begin_surface(m_vertices.size(), m_triangles.size()); for(std::vector<Point>::iterator vertexIterator = m_vertices.begin(); vertexIterator != m_vertices.end(); ++vertexIterator) { B.add_vertex(*vertexIterator); } for(std::vector<triangle>::iterator triangleIterator = m_triangles.begin(); triangleIterator != m_triangles.end(); ++triangleIterator) { B.begin_facet(); B.add_vertex_to_facet((*triangleIterator).indexA); B.add_vertex_to_facet((*triangleIterator).indexB); B.add_vertex_to_facet((*triangleIterator).indexC); B.end_facet(); } // //if ( B.check_unconnected_vertices() ) //{ // B.remove_unconnected_vertices(); //} B.end_surface(); } Now then, to convert my CGAL triangulation into the representation of m_vertices and m_triangles... I only want the convex hull, so I only consider the cells connected to the infinite vertex. Then it gets a little sketchy.. from the facet of the exterior cell (incident to the infinite vertex) making up part of the polyhedron surface, I need the counter-clockwise (?) order of the vertices. I based myself on http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html for this. In the first image, the vertices indices are shown. std::vector<Vertex_handle> m_vertexHandles; void fillWithRealData(const Dt& DelaunayTriangulation) { // store the vertex handles
for(int i = 0; i < m_vertexHandles.size(); ++i) m_vertices.push_back(m_vertexHandles[i]->point()); // get all the cells connected to the infinite vertex (cells that make up the boundary/surface) std::vector<cellHandleDh> exteriorCells; DelaunayTriangulation.incident_cells(DelaunayTriangulation.infinite_vertex(), std::back_inserter(exteriorCells)); triangle triangleInstance; // for these exterior cells, get the triangle vertices that make up the surface of the triangulation and add them to m_triangles for(std::vector<cellHandleDh>::iterator triangleIterator = exteriorCells.begin(); triangleIterator != exteriorCells.end(); ++triangleIterator) { // check which of the vertices are the correct facet, and which order the vertices must appear in if((*triangleIterator)->vertex(0) == DelaunayTriangulation.infinite_vertex()) { triangleInstance.indexA = getVertexHandleIndex((*triangleIterator)->vertex(3)); triangleInstance.indexB = getVertexHandleIndex((*triangleIterator)->vertex(2)); triangleInstance.indexC = getVertexHandleIndex((*triangleIterator)->vertex(1)); } else if((*triangleIterator)->vertex(1) == DelaunayTriangulation.infinite_vertex()) { triangleInstance.indexA = getVertexHandleIndex((*triangleIterator)->vertex(0)); triangleInstance.indexB = getVertexHandleIndex((*triangleIterator)->vertex(2)); triangleInstance.indexC = getVertexHandleIndex((*triangleIterator)->vertex(3)); } else if((*triangleIterator)->vertex(2) == DelaunayTriangulation.infinite_vertex()) { triangleInstance.indexA = getVertexHandleIndex((*triangleIterator)->vertex(0)); triangleInstance.indexB = getVertexHandleIndex((*triangleIterator)->vertex(3)); triangleInstance.indexC = getVertexHandleIndex((*triangleIterator)->vertex(1)); } else if((*triangleIterator)->vertex(3) == DelaunayTriangulation.infinite_vertex()) { triangleInstance.indexA = getVertexHandleIndex((*triangleIterator)->vertex(2)); triangleInstance.indexB = getVertexHandleIndex((*triangleIterator)->vertex(0)); triangleInstance.indexC = getVertexHandleIndex((*triangleIterator)->vertex(1)); } else assert(0); m_triangles.push_back(triangleInstance); }
int getVertexHandleIndex(Vertex_handle vertexHandle) { for(int i = 0; i < m_vertexHandles.size(); ++i) { if(m_vertexHandles[i] == vertexHandle) return i; } assert(0); return -1; } I also tested this with points generated by CGAL in a sphere, but this didn't produce correct results. Polyhedron::is_closed() and Polyhedron::is_valid() didn't return true and I get: ==== summe border halfedges (2*nb) = 0 vertex 0 halfedge 0 halfedge 1 halfedge 2 halfedge 3 vertex 1 halfedge pointer in vertex corrupted. end of CGAL::HalfedgeDS_const_decorator<HDS>::is_valid(): structure is NOT VALID . counting halfedges failed. ==== Does the order in which the triangles are added (B.begin_facet() ...) matter perhaps? I also looked at Polyhedron_3.make_triangle(...), but I assume this doesn't do what I want? It didn't really produce correct results as far as I know. Any help is greatly appreciated. > Date: Wed, 19 Nov 2008 12:09:56 -0800 > From: > To: > Subject: Re: [cgal-discuss] Triangulation to Polyhedron > > i had the same problem, i solved it by using the incremental builder. > > in my program, i need to re-triangulate triangles on a 3D surface. i > first do the triangulation in 2D. and then use the incremental builder > to create the same triangulation in 3D in the polyhedron_3 format. and > finally attach the re-triangulated piece to the original surface. > > actually, i didn't use the triangulation feature of the CGAL, i used > another library. because in my case, the thing that needs to be > triangulated may be a concave polygon. i don't know how CGAL can do > the triangulation while preserving the concave border. > > > > On Wed, Nov 19, 2008 at 11:48 AM, <> wrote: > > Hi, > > > > How do you convert a Delaunay_triangulation_3 object to a Polyhedron_3 > > object? > > > > I tried to use CGAL::assign(), but it didn't work. > > > > > > Thank you. > > > > ________________________________ > > Alle fun stuff van Messenger nu verzameld op één coole site! Windows Live > > Messenger > > > > -- > Dept. of Computer Science > University of California, Davis > Homepage:http://wwwcsif.cs.ucdavis.edu/~yans/ > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss De nieuwe Hotmail maakt je leven nog makkelijker Wees er als eerste bij. |
- [cgal-discuss] Triangulation to Polyhedron, pgoeleven, 11/19/2008
- Re: [cgal-discuss] Triangulation to Polyhedron, Andreas Fabri, 11/19/2008
- RE: [cgal-discuss] Triangulation to Polyhedron, pgoeleven, 11/19/2008
- Re: [cgal-discuss] Triangulation to Polyhedron, Shi Yan, 11/19/2008
- RE: [cgal-discuss] Triangulation to Polyhedron, pgoeleven, 11/20/2008
