cgal-discuss - Re: [cgal-discuss] error C2662 in creating a surface class for surface
  • To:
  • Subject: Re: [cgal-discuss] error C2662 in creating a surface class for surface
  • Date: Sat, 22 Nov 2008 10:44:45 +0100
  • Organization: INRIA
hi Amir,
I attach an example polyhedral oracle where the input surface is a polyhedron for inspiration.
let me know if you want the complete aabb_tree business if you want to try it.
a écrit :
Hello,
I am trying to create my own surface_3 type for the surface mesh generation,
and ran into an error I can't diffuse. This is the essence of my definition
code:
(Line3D, Segment3D and Ray3D were defined in another file as the regular
kernel::line_3 etc.)
class MeshSurface{
public:
class MeshIntersect{
public:
CGAL::Object operator()(MeshSurface surface, Line3D l);
CGAL::Object operator()(MeshSurface surface, Ray3D l);
CGAL::Object operator()(MeshSurface surface, Segment3D l);
MeshIntersect(){}
~MeshIntersect(){}
class MeshInitialPoints{
public:
template <class OutputIteratorPoints>
OutputIteratorPoints operator()(MeshSurface surface,
OutputIteratorPoints pts, int n=20)
MeshInitialPoints(){}
~MeshInitialPoints(){}
MeshInitialPoints(const MeshInitialPoints& mip){}
MeshInitialPoints& operator=(const MeshInitialPoints&
mip){return (*this);}
class MeshTraits{
public:
typedef Point3D Point_3;
typedef Segment3D Segment_3;
typedef Ray3D Ray_3;
typedef Line3D Line_3;
typedef MeshSurface Surface_3;
typedef MeshIntersect Intersect_3;
typedef MeshInitialPoints Construct_initial_points;
MeshIntersect intersect_3_object (){return MeshIntersect();}
MeshInitialPoints construct_initial_points_object (){return
MeshInitialPoints();} MeshTraits(){}
~MeshTraits(){}
MeshTraits(const MeshTraits& mi){}
MeshTraits& operator=(const MeshTraits& mi){return (*this);}
typedef MeshTraits Surface_mesher_traits_3;
MeshSurface():{...}
MeshSurface(const MeshSurface& ms){...}
MeshSurface& operator=(const MeshSurface& ms){return MeshSurface(ms);}
~MeshSurface(){...};
I get the error "error C2662:
'MeshSurface::MeshTraits::construct_initial_points_object' : cannot convert
'this' pointer from 'const MeshSurface::MeshTraits' to
&' c:\program files\cgal-3.3\include\cgal\make_surface_mesh.h".
I do have a copy constructor for MeshTraits, so I am missing something here.
Why does that happens?
Thanks,
Amir Vaxman
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
// Copyright (c) 2008 INRIA Sophia-Antipolis (France), ETHZ (Suisse).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
https://scm.gforge.inria.fr/svn/cgal/trunk/AABB_tree/include/CGAL/AABB_tree/AABB_polyhedral_oracle.h
// $Id: AABB_polyhedral_oracle.h 46267 2008-10-14 12:15:10Z palliez $
// Author(s) : Camille Wormser, Jane Tournois, Pierre Alliez
#ifndef CGAL_AABB_POLYHEDRAL_ORACLE_H
#define CGAL_AABB_POLYHEDRAL_ORACLE_H
#include <boost/static_warning.hpp>
#include <utility>
#include <CGAL/iterator.h>
#include <CGAL/AABB_tree/AABB_tree.h>
namespace CGAL {
template <class Polyhedron, class Kernel, class AABBTree_kernel>
class AABB_polyhedral_oracle : public Polyhedron
public:
typedef typename Kernel::FT FT;
typedef typename Kernel::Ray_3 Ray_3;
typedef typename Kernel::Line_3 Line_3;
typedef typename Kernel::Point_3 Point_3;
typedef typename Kernel::Segment_3 Segment_3;
typedef AABB_polyhedral_oracle<Polyhedron,Kernel,AABBTree_kernel> Self;
typedef Self Surface_mesher_traits_3;
typedef Point_3 Intersection_point;
typedef Self Surface_3;
// AABB tree
typedef AABB_tree<AABBTree_kernel,typename
Polyhedron::Facet_handle,Polyhedron> Tree;
typedef typename Tree::Point_with_input Point_with_facet_handle;
typedef CGAL::Cartesian_converter<Kernel,AABBTree_kernel> Converter;
typedef CGAL::Cartesian_converter<AABBTree_kernel,Kernel> BConverter;
Tree *m_pTree;
public:
Tree* tree() const { return m_pTree; }
public:
// Surface constructor
AABB_polyhedral_oracle()
m_pTree = NULL;
AABB_polyhedral_oracle(Tree *pTree)
m_pTree = pTree;
AABB_polyhedral_oracle(const AABB_polyhedral_oracle& oracle)
m_pTree = oracle.tree();
class Intersect_3;
friend class Intersect_3;
class Intersect_3 {
const Self& self;
public:
Intersect_3(const Self& self) : self(self)
Object operator()(const Surface_3& surface, const Segment_3& segment)
const
Converter convert;
BConverter bconvert;
Point_with_facet_handle pwh;
if(surface.tree()->first_intersection(convert(segment),pwh))
return make_object(bconvert(pwh.first));
else
return Object();
Object operator()(const Surface_3& surface, const Ray_3& ray) const
Converter convert;
if(surface.tree()->first_intersection(convert(ray),pwh))
else
return Object();
Object operator()(const Surface_3& surface, const Line_3& line) const
Converter convert;
if(surface.tree()->first_intersection(convert(line),pwh))
else
return Object();
Intersect_3 intersect_3_object() const
return Intersect_3(*this);
class Construct_initial_points;
friend class Construct_initial_points;
const Self& self;
public:
Construct_initial_points(const Self& self) : self(self)
template <typename OutputIteratorPoints>
OutputIteratorPoints operator() (const Surface_3& surface,
OutputIteratorPoints out,
int n) const
// TODO (with visitor)
std::cout << "AABB_polyhedral_oracle: construct initial point set not
implemented" << std::endl;
// *out++= p;
return out;
Construct_initial_points construct_initial_points_object() const
return Construct_initial_points(*this);
template <class P>
bool is_in_volume(const Surface_3& surface, const P& p)
std::cout << "call is in volume: empty function" << std::endl;
return true;
}; // end class AABB_polyhedral_oracle
} // end namespace CGAL
#endif // CGAL_AABB_POLYHEDRAL_ORACLE_H
