- To:
- Subject: Re: [cgal-discuss] error C2662 in creating a surface class for
- Date: Mon, 24 Nov 2008 14:58:49 +0100
On Saturday 22 November 2008 11:05:44
wrote:
> Thank you! What worked is uniting the surface_mesh_traits with the
> surface_3 class and adding a few "consts" here and there..
Only the constification was really necessary. Actually. The error message was:
"cannot convert 'this' pointer from 'const MeshSurface::MeshTraits'
to 'MeshSurface::MeshTraits&'". It means that the compiler cannot convert an
object of type:
const MeshTraits
to:
MeshTraits&
The major difference between the two types it the const. Most probably the
operator() of MeshIntersect need to take the "surface" argument as const.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
--- Begin Message ---
- To:
- Subject: r46987 - trunk/Mesh_2/demo/Mesh_2
- Date: Sat, 22 Nov 2008 15:40:28 +0100
- List-archive: <http://lists.gforge.inria.fr/cgi-bin/mailman/private/cgal-commits>
- List-id: svn commits <cgal-commits.lists.gforge.inria.fr>
Summary
Revision in ViewCVS
New Revision: 46987
Author: lrineau
Date: 2008-11-22 15:40:27 +0100 (Sat, 22 Nov 2008)
Log message:
Remove an old piece of code that has been superseded by CGAL code in CGAL-3.3 (CGAL_assertion now triggers exceptions, by default).Modified files
trunk/Mesh_2/demo/Mesh_2/mesh_2_demo.cpp
Differences as text
Modified: trunk/Mesh_2/demo/Mesh_2/mesh_2_demo.cpp =================================================================== --- trunk/Mesh_2/demo/Mesh_2/mesh_2_demo.cpp 2008-11-21 20:03:28 UTC (rev 46986) +++ trunk/Mesh_2/demo/Mesh_2/mesh_2_demo.cpp 2008-11-22 14:40:27 UTC (rev 46987) @@ -1506,39 +1506,6 @@ "Shewchuk Triangle .poly files (*.poly);;" "All files (*)"; - -#include <CGAL/assertions.h> -#include <CGAL/assertions_behaviour.h> -#include <exception> - -CGAL::Failure_function my_previous_failure_function; - -class Cgal_exception : public std::exception { -public: - Cgal_exception(const char *t, - const char *e, - const char* f, - int l, - const char* m) - : type(t), expr(e), file(f), line(l), msg(m) {}; - - const char *type; - const char *expr; - const char* file; - int line; - const char* msg; -}; - -void cgal_with_exceptions_failure_handler( - const char *type, - const char *expr, - const char* file, - int line, - const char* msg) -{ - throw Cgal_exception(type,expr,file,line,msg); -} - int main(int argc, char** argv) { QApplication app( argc, argv ); @@ -1553,24 +1520,7 @@ if( argc == 2 ) W->openTriangulation(QString(argv[1])); - // my_previous_failure_function = - //CGAL::set_error_handler(cgal_with_exceptions_failure_handler); - - try { - return app.exec(); - } - catch(Cgal_exception e) { - std::cerr << "catch(Cgal_exception e)" << std::endl; - try { - W->dumpTriangulation(); - } - catch(...) { - std::cerr << "PANIC !!" << std::endl; - } - my_previous_failure_function(e.type, e.expr, e.file, e. line, e.msg); - } - - return 0; + return app.exec(); } // moc_source_file: mesh_2_demo.cpp
--- End Message ---
- [cgal-discuss] error C2662 in creating a surface class for surface meshing, avaxman, 11/22/2008
- Re: [cgal-discuss] error C2662 in creating a surface class for, avaxman, 11/22/2008
- Re: [cgal-discuss] error C2662 in creating a surface class for surface, Pierre Alliez, 11/22/2008
- Re: Re: [cgal-discuss] error C2662 in creating a surface class for, avaxman, 11/22/2008
- Re: [cgal-discuss] error C2662 in creating a surface class for, Laurent Rineau, 11/24/2008
