- To:
- Subject: Re: [cgal-discuss] Triangulation_3 input
- Date: Sun, 23 Nov 2008 17:17:11 +0100
This is the empty ball condition used for defining the Delaunay triangulation. When inserting a new point p, all simplices S such that p is inside the circumsphere of S are searched. This is the test side_of_oriented_sphere. At the beginning, the method checks if the four vertices of simplex S are oriented positively. This should not fail with a Filtered kernel. No, this reason would be valid if you were using an unfiltered kernel. I copy pasted your definitions (see code below), and I am unable to reproduce your problem. The program prints: triangulation of 10000 points computed in 1.56 s Are you sure you are really using these definitions? -- Camille --------------------------------------------------------------------------------- #include <CGAL/point_generators_3.h> #include <CGAL/copy_n.h> #include <list> // YOUR DEFINITIONS START HERE #include <CGAL/Simple_cartesian.h> #include <CGAL/Filtered_kernel.h> typedef CGAL::Filtered_kernel<CGAL::Simple_cartesian<float> > KernelFloat; #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel KernelDouble; typedef KernelFloat KernelActive; #include <CGAL/Delaunay_triangulation_3.h> #include <CGAL/Triangulation_hierarchy_3.h> typedef CGAL::Triangulation_vertex_base_3<KernelActive> TVB; typedef CGAL::Triangulation_hierarchy_vertex_base_3<TVB> THVB; typedef CGAL::Triangulation_data_structure_3<THVB> TDS; typedef CGAL::Delaunay_triangulation_3<KernelActive, TDS> DT; typedef CGAL::Triangulation_hierarchy_3<DT> CGAL_Triangulation; typedef CGAL_Triangulation::Point CGAL_Point; typedef CGAL_Triangulation::Vertex_handle CGAL_VertexHandle; typedef CGAL_Triangulation::Finite_vertices_iterator CGAL_FiniteVerticesIter; typedef CGAL_Triangulation::Cell_handle CGAL_CellHandle; // YOUR DEFINITIONS END HERE #include <boost/progress.hpp> #include <iostream> #define N 10000 int main() { CGAL_Triangulation triangulation; typedef CGAL::Random_points_on_sphere_3<CGAL_Point> Generator; std::list<CGAL_Point> collection; CGAL::copy_n(Generator(1.), N, std::back_inserter(collection)); std::cout << "triangulation of " << N << " points computed in "; { boost::progress_timer timer(std::cout); triangulation.insert(collection.begin(), collection.end()); } return 0; } |
- [cgal-discuss] Triangulation_3 input, pgoeleven, 11/23/2008
- Re: [cgal-discuss] Triangulation_3 input, Camille Wormser, 11/23/2008
- RE: [cgal-discuss] Triangulation_3 input, pgoeleven, 11/23/2008
- Re: [cgal-discuss] Triangulation_3 input, Olivier Devillers, 11/23/2008
